I recently purchased a Perma-Cool Fan 14in fan for my Vette. I didn't really think this was enough, but the CFM rating was 2950. I guess I don't have enough surface area covered on my radiator. Anyway, it overheats everytime you stab the throttle. Summit said I could send it back, so I need to see what fan I need to get. I would really like to get some duals that are strong enough where I can get rid of my ugly fan shroud. Dewitts has a really nice set-up, but I can't afford it. I really can't spend more than about $250. Any ideas? I still have my stock radiator, so maybe I could go to Aluminum, but I would still likely have to keep my fan shroud.
Thanks in advance,
Jay
Re: Overheating with Electric Fan (TeenagerWith74Vette)
Check around and see if you can find a shroud and fan setup from a late model F-Body Camaro or Firebird. Several guys have installed these for less than $200.00, It will take a little triming to fit around the upper control arms, but it shouldn't be too hard of an installation. Check with http://www.Corvettefaq.com there are a couple of write-ups with pictures there.
Of course as you said the best alternative is the DeWitts twin Spal, but if you are short on cash, then the F-Body fans will do the job.
Dual Spal fans here. They work great.
IMHO, you obviously have built yourself a very serious engine combo. It would be a shame to overheat and ruin a major investment by trying to save a few $$ on a cheap fan.
It is common for people to upgrade the motor without paying attention to the support systems. They then pay the price when the motor overheats and does itself some major damage.
Will the dual Spal's keep me cool with my stock radiator, and no shroud. I really need to get something done. I'm itching to get back to the track, but I have to get my cooling problem fixed. I really want to get down the track with my new 4.11s and slicks!
Jay
Looks like you have done a lot to your engine. But this still begs a questions, what have you done for the radiator? Have you had it professionally tanked? The reason I ask is that I'm running a 16" single electric fan on and old 1970 350 engine in need of a rebuild yet still won't crack 180 degrees even at wot. I have had the radiator cleaned along with new hoses etc.... its the original 3 core radiator that looks older than my old grandmother, but it works great! Also, do you have the seals and airdam in place?
Had the same fan on the 502- it lasted 3 days! Try the dual SPAL's-works for me............
:yesnod: :chevy :chevy :yesnod:
P.S.
All the motor work in the world isn't worth a nickel if you can't run it reliably.
You can also use 90-96 Corvette dual fans that can be found at practically any corvette swap meet. Additionally, all the parts are available if you need a new fan motor.
steveg75 is right on target here. The cooling system is no place to scrimp out. That said, I might have a solution for you. The typical 2 row (1.0" tube) aluminum radiator runs $495. I happened to have a demo HP series (1.25" tubes) that we painted for testing purposes. It is a 73-76 radiator but it's a manual transmission, no tranny cooler. You could use this radiator and a separate transcooler, your tranny would appreciate it as this is a much better idea anyway. I'd sell this guy for $400. Griffin model 6574AF-BXX. My first recommendation is to spend the money on the radiator first, then the other stuff later. A good radiator is the foundation, then you build on that.
If you dont mine spending the money, I installed Dual Flex a Lite fans on my 454, and they are coolng the Monster no problems. They are a sweet looking set-up, very easy to install.
I wouldn't run out and spend too much money, just yet. Make sure what you have is truly broken. It's like Jim said: Are your seals in good shape? Are you sure your thermostat is working? Do you have air in the system? When was the last time you flushed the cooling system? What about your water pump and fan belt? Check all these things first, because it's cheap. And it's silly not too. Once you're sure all this is okay, then go looking for other, more expensive solutions. I had overheating problems too. And I was so eager to drive my car, I nearly threw down big bucks for a quick (but not guaranteed) solution. Then I took a deep breath, and I went on a mission to find out what was really wrong. A whole bunch of the above stuff was the source of my cooling problems. Then, after a new pump, long bleeding session, and discovering my BRAND NEW thermostat was garbage, I solved my overheating issues.
I just put in a 160* thermostat, but I haven't tried it yet. I don't think my Perma-Cool will cut it. All of my seals look good, and I have a new waterpump. A fellow CF Member offered a Flex-A-Lite for sale. I think I'm gonna take him up on that. I would love to get Tom's stuff. But I don't have the cash! It's expensive to have a low 12 second daily driver Vette!
Jay
I'm running the Flex-a-lite dual 12" fans with a Griffin Universal (31x19, 2 row 1.25" tubes). I bought the fans used and the rad new from Summit for $260. I put them in in Oct of last year, so I don't know how it will stand up in the Dallas heat, but even 70* weather requires about 5 -10 min of sitting in traffic to get the fans to come on.
I'm thinking of buying the Flex-A-Lite dual fans from a CF member. But, they won't fit without removing my Fan Shroud. What do ya'll think about that? The Flex-A-Lite has dual 12in fans and the measurements are 22x14x4. I think the fans would work great, but will I get enough air when I remove the shroud? I would love to get rid of that ugly thing! Thnks for your input.
Jay
Get a Griffin or BeCool. WAYYY more cooling capacity. Unfortunately, they're expensive. I paid almost $600 for my Griffin.
I have a Flex-A-Lite Black Magic M150 single fan mounted inside my stock shroud. It has its own little shroud with a rubber lip that squishes up against the radiator to make sure the air flows through, not around.
Pictured here is my stock shroud, with the top cut away (to fit my TPI hardware above) and the original '82 aux fan inside. The Flex-A-Lite Black Magic assembly is off to the right. It just barely fit inside the stock shroud.
The flex-a-lite dula 12" fans have a built in shroud so you are supposed to ditch the stock shroud.
I'll again point out that the universal Griffin radiator fits my '69 with very little modification and cost about $260. From what I've found, this radiator has the same 1.25" tubes that the $500 Corvette specific rads have.
