Muncie Oil Capacity
(1973 350 with a 32 spline Muncie 4 spd)
thanks
Jim
One other question. Behind the clutch fork there is a front cover over the base of the input shaft. Mine was leaking a bit.... Can I resolve that with some RTV or do I need to make/buy a gasket? I was on a Chevelle site where they were talking about using a gasket made from a rice crispies box (go figure but I guess it's about the same material as gasket material). Thought I'd see if you had an opinion.
thanks
Jim
I do recall the issue with the drain hole, but there is some useful discussion regarding leaking front bearings here.
http://www.chevelles.com/forums/showthread.php?t=69355
Darrel comes to Carlisle every year and does quite a lot of business with Muncies, I wouldn't hesitate to give him a call and ask him for advice. He always has a crowd at his booth and appears very helpful.
http://www.darrelsrepair.com/aboutus.php
Good luck... GUSTO
thanks
Jim
Are there locking tabs on the retaining bolts? Those are available as well if you have to destroy them in the process.
