water outlets
Old Dec 6, 2010 | 08:31 AM
dembo's Avatar
dembo
Default water outlets
Gentlemen,
Can anyone confirm if the indicated port is also a water outlet where I could bolt in a temperature sender please? (before I drain the water and take it out) It would be nice if it was so I can use it for my electric fan controller.
Its a 350HO crate engine with intake manifold PN 12496820
Cheers,
Nick
Old Dec 6, 2010 | 09:38 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Yes you can It ports right into the water jacket of the manifold.
BTW your thermostat is upside down.
Also the other sensor in the picture,it's threaded into a adapter bushing, I may not allow the temp bulb to
sit in the water jacket resulting in inaccurate readings
Old Dec 6, 2010 | 09:42 AM
dembo's Avatar
dembo
thank you sir,
lol about thermostat, I also just noticed, good eye knowing myself i would have tried to mount it like that as well I just put it in to avoid things droping in the manifold
Nick
To water outlets
