Rust encapsulation advice/products?
Old Dec 6, 2010 | 05:53 PM
Raider74's Avatar
Raider74
Default Rust encapsulation advice/products?
I just got my new polyurethane body mounting kit and hardware and am going to use the method of lifting one side at a time with a floor jack+supports to replace my body mounts. While I am in there I want to paint/coat my frame rails and the body frame rails. I intend to do a light sanding to get off the loosest of surface rust, and then was wondering what product might be good to paint over the rest of it?
Old Dec 6, 2010 | 07:07 PM
72LS1Vette's Avatar
72LS1Vette
I've used Eastwood Rust Encapsulator and RustBullet. Either works well and requires minimal preparation. The Eastwood product left some brush marks while RustBullet flows better. RB needs 2 coats though. RB also needs some scuffing before applying a topcoat unless you like the silver color. Eastwood leaves a primer-like surface that can be topcoated.
Rick B.
Old Dec 6, 2010 | 11:54 PM
dboz's Avatar
dboz
POR 15 is pretty good also.
To Rust encapsulation advice/products?
