washer sac
Old Apr 7, 2002 | 10:44 AM
72SHARK383's Avatar
72SHARK383
Default washer sac
Looking to p/u window washer sac but can't find one.
Old Apr 7, 2002 | 12:56 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
Default Re: washer sac (72SHARK383)
I'm assuming that the "sac" that you refer to is the Winshield Washer Bag that was used on 69-72 Corvettes w/ A/C? Non-A/C Vettes used a plastic "bottle" type reservoir.
Hopefully this picture will show up:
I found this picture at Rik's Unlimited Corvette Parts website .... http://www.riksvet.com/
It is part number WSW111 and sells for $49.95.
Hope this helps!!
Old Apr 7, 2002 | 02:53 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Since looking at your mods, it seems pretty obivous that you aren't looking for total originality. So you can do what I did and buy one from PepBoys, Autozone or just about any chain type autoparts. I bought one for about $9.00 that came with a little pump built in, I didn't use the pump, I just drilled a hole in the cap, ran a pickup hose through it into the bag. Then I hooked that hose up to the pump pickup on my wiper/washer pump. I also had to plug off the discharge of the little pump in the bottom of the bag to keep the water from running out.
The little bag I bought even had two brass grommets that matched up pretty good with the bag holder up under the driver's side fender. It was a cheap fix that works as good as the original and isn't noticeable to anyone but an NCRS judge.
To washer sac
