Fuel Supply (pump ?) problem
Old Dec 12, 2010 | 03:53 PM
bucksy99's Avatar
bucksy99
Default Fuel Supply (pump ?) problem
Hi all
I am working on my 75' and can't get any fuel out of the line. Cleaned the tank and the supply line to the pump. I could siphon fuel out of that line with a hand pump. However the original pump didn't pump anything. I put then a new pump in making sure that the pushrod sits on the lever of the new pump. Still, when I crank the engine I get nothing.
What could be the problem at this point ?
Thanks in advance for any input.
Old Dec 12, 2010 | 04:24 PM
noonie's Avatar
noonie
Hook a temporary long hose onto the pump outlet (easy at the carb end of line), other end into a bucket, and crank engine to test the pump alone.
Old Dec 12, 2010 | 06:02 PM
Tommy Almond's Avatar
Tommy Almond
Be sure and check your rubber S hose from line on frame rail to pump, if closed will not allow fuel to pass into fuel pump. Ask me know I know.......from experience that was my problem on my '81.
Old Dec 13, 2010 | 02:09 PM
bucksy99's Avatar
bucksy99
Thanks but I was able to siphon fuel out with a hand pump. So I think the problem must be the pump or the push rod.
Noonie, I disconnected the line from the carb and put an old plastic container at the end, so I know for sure nothing is coming out.
Any other thoughts ?
Thanks again.
Old Dec 13, 2010 | 09:52 PM
my 76 ray's Avatar
my 76 ray
If you are not getting a perfect seal between the hose and the pump, you will not get gasoline to flow. Your hand pump probably has a different fitting than the pump, so being able to get fuel with the hand pump may not prove anything. It's another one of those "ask me how I know" things.
If you happen to be a courageous or maybe foolish person, you could put a hose from the fuel pump into a gasoline can and see if it pumps from there. But, it could be hazardous so do that at your own risk.
Old Dec 14, 2010 | 07:09 AM
bucksy99's Avatar
bucksy99
I have been told to be both...
I will give it a try. Thanks
Old Dec 14, 2010 | 08:21 AM
noonie's Avatar
noonie
You should really be able to start a suction action on the supply line at the front frame and just let it run into a bucket very, very freely.
Test your pushrod to see if it moves up and down with the engine cranking.
You can either have a worn pushrod, worn cam lobe or a bad pump.
First 2 aren't common at all.
Old Dec 14, 2010 | 08:24 AM
noonie's Avatar
noonie
For at least 30 years, that's the method I always use to purge the fuel lines of these old cars when changing the fuel filters.
Amazing how much crap can come out between filter changes.
Old Dec 14, 2010 | 11:01 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
When you changed the pump did the main feed line free flow? There is no restiction in that line and it should gravity flow to the pump. If you do not get any flow out of that line I would look for a restriction as mentioned in the rubber lines by the tank and then follow the main steel line looking for a kink.
Old Dec 14, 2010 | 04:05 PM
LB66383's Avatar
LB66383
It's rare, but sometimes the pump will not pump any gas, or pump only a very little, at cranking speed. If the engine is all together and ready to run, which I assume it is, pour gas into the carburetor bowl through the vent tube. That will run the engine for a minute or two. Put the fuel line from the pump into your bucket, and start the engine. That will show you if the pump is actually moving any fuel. As always, have someone standing by with a fire extinquisher.
Old Dec 19, 2010 | 02:37 PM
bucksy99's Avatar
bucksy99
Sigforty, you are right.
I siphoned the line again and now it is gravity flowing out of that line.
I cranked the engine a couple times and it pumped it out a little. Then the battery died.
The fuel looks really dark yellow though and I wonder if I should drop the tank and clean it instead of trying to pump all the particles out.
Old Dec 20, 2010 | 09:42 PM
Sigforty's Avatar
Sigforty
You can drop the tank, or you could pull the sender out the bottom and drain it without dropping the tank. I would suggest taking a flashlight to the filler neck and glancing around in the tank. When I would fill up my car I was able to see the bottom of the tank as I filled up. Depending on the gas you use and the additives in it, it is normally a slightly yellow clear fluid. You may have a bad sock on the main feed with the sender in the tank.
Old Dec 21, 2010 | 01:37 AM
sly vette's Avatar
sly vette
Did you check for a inline filter between the tank and pump. They were used quite a bit in the 70's and 80's. I imagine you did if you cleaned the line. If you don't have one it sounds like your sock may be pluged.
Never mind if you now get a free flow from the line before the pump.
It's begining to sound like a bad pump.
I don't know if you tank should be vented or not but I know a few guys here have had a issue in that respect also. Does it flow the same with the gas cap on as on as well as off?
Could be a worn rod or lobe on the cam but I agree with noonie that it would be rare.
To Fuel Supply (pump ?) problem
