starter keeps going with igniton off
Old Dec 15, 2010 | 02:13 PM
markhperry's Avatar
markhperry
Default starter keeps going with igniton off
69 427/400 vert I can turn ignition on and starter turns over fine, but if i turn key off it still trys to crank. Starter and solenoid work fine off car. Any suggestions?
Old Dec 15, 2010 | 02:32 PM
wombvette's Avatar
wombvette
Wired wrong.
Old Dec 15, 2010 | 02:45 PM
Gilded_Splinters's Avatar
Gilded_Splinters
That's what I would have said too provided it's a new or newly installed switch.
If its old and just started doing this, I would guess that the switch has gone bad. I had this happen on a boat this past year.
Old Dec 15, 2010 | 03:05 PM
markhperry's Avatar
markhperry
I thought it might be the switch. It has just started this. Is there a way to get to that switch without dropping steering column?
Old Dec 16, 2010 | 08:22 AM
tommyleea's Avatar
tommyleea
I would shoot the wires before replacing anything. Disconnect the small wire at the starter, and see if you are getting power to it even when the switch is not in the start position.
Old Dec 16, 2010 | 09:12 AM
markhperry's Avatar
markhperry
The small wire at starter, are you talking about the wire on the R terminal or S terminal
Old Dec 16, 2010 | 10:42 AM
Peterbuilt's Avatar
Peterbuilt
Turning the key switch to "START" sends battery voltage to the S terminal on the starter.
The S terminal wire is purple and is connected to the solenoid terminal closest to the block.
When the purple wire is energized the solenoid coils pull in and that sends power to the starter and the yellow R terminal wire.
Once you turn the key to run or any other position there should not be any power in the S terminal.
Old Dec 16, 2010 | 10:54 AM
iveym5's Avatar
iveym5
Had that happen to me once when I was a teenager. I had cranked the motor over for too long because it wouldn't start. The wires going down to the starter overheated from the current draw and melted together shorting them out. I had to jump out and yank the battery cables off to get it to stop.
Old Dec 16, 2010 | 10:59 AM
markhperry's Avatar
markhperry
So if I have voltage at the S terminal in the run position where is my problem?
Old Dec 16, 2010 | 01:19 PM
...Roger...'s Avatar
...Roger...
Try doing this,disconnect the purple from the S term on the solenoid,put a test light on the purple wire,turn your key to start,confirm test light lights,then release key to ON position,if light stays lit the ignition switch is bad or misadjusted,if the light goes out its something wrong with the starter.
Old Dec 16, 2010 | 02:44 PM
markhperry's Avatar
markhperry
So when I turn the key ON there should be no voltage on the S terminal. There should be voltage in the RUN position. Correct?
That seems to be different from what pete74 is saying
Old Dec 16, 2010 | 03:09 PM
...Roger...
No Petes correct,were getting our positions mixed up.
Run is ON , the position that the engine runs in as your driving down the road
Start is start or crank when the key is forced all the way against spring pressure
In the Start position the purple and the S terminal should have power.
In the On position the purple and S should not have power BUT the yellow and the R terminal should have power.
If the yellow is accidentally put on the S terminal with the purple the engine will start but the starter will remain cranking in the ON position also. Like is happening to your car.
Old Dec 16, 2010 | 04:45 PM
markhperry's Avatar
markhperry
thanks
Old Dec 17, 2010 | 12:43 AM
troutster71's Avatar
troutster71
From: Albuquerque Resistance is not futile. It's voltage divided by current.
Default I changed the solenoid
Had this exact problem on my friends '68 427 Camaro. We were pulling
our hair out when we started changing parts. That was after many
creative and exhaustive electrical checks. And yes, it was wired
correctly. Finally changed the solenoid and that fixed it.
Also worked fine off the car, had to be some sort of load induced
short in the solenoid. I believe it was an Autozone reman unit.
Hope this helps, Gary
Old Dec 17, 2010 | 10:42 AM
Peterbuilt's Avatar
Peterbuilt
Originally Posted by ...Roger...
Try doing this,disconnect the purple from the S term on the solenoid,put a test light on the purple wire,turn your key to start,confirm test light lights,then release key to ON position,if light stays lit the ignition switch is bad or maladjusted,if the light goes out its something wrong with the starter.
Try this test and post back the results.
Old Dec 18, 2010 | 12:03 PM
markhperry's Avatar
markhperry
I have checked the S wire and the R wire... The S wire has no voltage in the Run position and voltage in the Start position. The R wire has voltage in the run position, So I guess my starter is bad.. It works fine off car, I guess it could be a load problem. It has a new solenoid and starter has been rebuilt. I will pull starter and have it checked again. Any other suggestions
To starter keeps going with igniton off
