82 CE fuse block problem
Old Dec 16, 2010 | 11:13 AM
bhalo65's Avatar
bhalo65
2nd Gear
Default 82 CE fuse block problem
Anyone ever had the fuse block corrode random things stop working then I wire brush the fuses and clean the block and they work again. What I would like to do is just replace the whole fuse block does anyone know were I can get one.............................
Old Dec 16, 2010 | 11:21 AM
straub18045's Avatar
straub18045
think 'painless wiring' mite
Old Dec 16, 2010 | 12:45 PM
bhalo65's Avatar
bhalo65
2nd Gear
need it to be original selling the car..............
Old Dec 16, 2010 | 02:37 PM
hugie82's Avatar
hugie82
I think the mid 80s Caddy's have the same fuse block and the most likely don't have the water damage most corvettes have. Also you can check the different suppliers, they all offer different sections of wiring harnesses
Old Dec 17, 2010 | 12:03 AM
jdp6000's Avatar
jdp6000
I don't know how hard it is but if you are going to go through the trouble of replacing it why not just remove it and give it a good cleaning?
Jim
Old Dec 17, 2010 | 12:26 AM
terry82's Avatar
terry82
any of the vette junk yards can sen you a good old one .or you can get a new one from several of the wire companys .
To 82 CE fuse block problem
