Pro charger setup info
Old Dec 16, 2010 | 01:32 PM
corvettedave383's Avatar
corvettedave383
Default Pro charger setup info
I've fitting a pro charger d1-sc, in my 78 c3, i think there,s a few on here that have done that, did you guys have to change your standard c3 power steering pumps?, any other info tips, problems you guys had during your fitting process
Thanks for any help
Cheers
Old Dec 16, 2010 | 01:46 PM
ylose's Avatar
ylose
Thanks for any help
Cheers
Big G was a great inspiration and help for me.
Steering:
Yes, I changed to the GM type II power steering punp. The main pain was plumbing the hoses......I dropped in a hydroboost (eliminate vacuum for brakes) which resolved much of that and cleared more room for the air intake of the Procharger.
Model:
Mine is also a '78, but a P1SC (for now anyways).
Engine
I have a RPM package on a crate 350 for now. I have a forged 377 in the corner of the garage waiting for this engine to blow.
Clearance
I had a friend who worked at a billet aluminum trucking place. He had someone fill some of the stock holes, for the blower mounting plate to the engine heads, and make me new ones. This allowed my blower to sit below the hood. Some have needed to cut away under the hood for clearance. I have an L88 hood for clearance of my carb hat, etc, on an air-gap intake for now.
Carb
I'm running a BG blowthrough carb
Status:
I'm at the stage to buy a belt and try it out without the air-to-air intercooler for now. I'll try to post up pictures soon.
Feel free to ask me whatever.
Old Dec 16, 2010 | 03:07 PM
corvettedave383
Steering:
Model:
Engine
Clearance
Carb
Status:
Thanks for the great info, I already have hydroboost fitted, my worry was the gm type 2 wasn't going to work it right, or somthing like that
Let me know how it goes, the pro charger is on it's way, so try and get started soon
Cheers mate, Dave
Old Dec 16, 2010 | 04:12 PM
corvettedave383
does your steering pump still run on separate belt?, ie not the same as the procharger?
cheers
dave
To Pro charger setup info
