firing order?
Old Dec 17, 2010 | 03:51 PM
whoodiestyle's Avatar
whoodiestyle
Default firing order?
I changed out my cap and rotor and I switched two plugs around not sure which ones but need to know the order on the distributor. Cause its obviously wrong when I start up the car.
Old Dec 17, 2010 | 03:53 PM
DRC's Avatar
DRC
Originally Posted by whoodiestyle
i changed out my cap and rotor and i switched two plugs around not sure which ones but need to know the order on the distributor. Cause its obviously wrong when i start up the car.
18436572
Old Dec 17, 2010 | 03:59 PM
whoodiestyle
I put it in that order now sounds even worst
Old Dec 17, 2010 | 04:03 PM
DRC's Avatar
DRC
Are you sure you have the rotor pointing to #1 plug as a correct starting point?
Old Dec 17, 2010 | 04:09 PM
mds3013's Avatar
mds3013
Are you going in a clockwise direction while looking down on top of dist.? Cylinders 1357 are on drivers side, 2468 on pass. side, from front of engine to back. mike...
Old Dec 17, 2010 | 04:33 PM
whoodiestyle
Not sure. I wish there was some kind of picture of the distributor or something with the order I don't understand how I messed this up
Old Dec 17, 2010 | 04:51 PM
Steve439's Avatar
Steve439
http://www.google.com/imgres?imgurl=...1t:429,r:1,s:0
Old Dec 17, 2010 | 05:01 PM
whoodiestyle
Thanks Steve439 working like a champ now
Old Dec 17, 2010 | 09:35 PM
72LS1Vette's Avatar
72LS1Vette
Next time change the wires one at a time and you won't have any problems.
Rick B.
Old Dec 19, 2010 | 03:42 PM
SoCalErv's Avatar
SoCalErv
Army
I am glad your car is running. I am posting this for anyone else that may need the information searching in the future.
Finding #1 Wire on the Distributor Cap
The compression stroke of the #1 cylinder is where the firing order begins. To determine that, you would need to remove the #1 spark plug, hold your finger over the hole, and tap the engine over slowly until the pressure pushes your finger (it won't hurt), and the timing mark should be nearing TDC. At that point is where the #1 plug wire on the distributor cap should line up with the terminal that the rotor is pointing to You will need to remove the distributor cap to look.
But, from your story, I'm assuming that the engine ran fine with the plug wires where they are on the distributor cap, and the wires just got crossed at the plugs? Then there is an easier way. Take a timing light (hope you have one), and attach it to one of the plug wires on the left bank (1-3-5-7). Have someone crank the engine over and you point the timing light at the timing tab by the harmonic balancer. The #1 plug wire will make the timing mark visible on the balancer. Now that you know which one is your #1 plug wire, you can follow the timing diagram clockwise around the distributor cap to check the rest of them.
To firing order?
