Headlight locking mechanism help...
Old Dec 18, 2010 | 11:47 PM
behardt91's Avatar
behardt91
Default Headlight locking mechanism help...
When my passenger's side healight is raised up, it locks and can't be pushed back down by pushing on the headlight lid. But on the driver's side, the headlight doesn't seem to lock like the other side and you can push it down. Anyone had this problem? Also when the headlights are turned off after having been on, one light will close before the other.
Old Dec 19, 2010 | 05:16 AM
dgood's Avatar
dgood
When my headlights are up, I can not push them down. They are supposed to lock into position. One of the screws may be out of adjustment on you drivers side. There is a slight pause with my lights when they go down. Maybe a second or two and then the other one will go down. You may have a leak in one or maybe the boots are bad on your diaphragm. Go to WILCOX website and they have a troubleshooting guide. Good luck
Old Dec 19, 2010 | 09:57 AM
wombvette's Avatar
wombvette
Two things to look at. There is a stop on the outer rim of the bucket. It is adjustable. If hitting too early the bucket wont lock up. See if your bucket is high as it is supposed to be.
Second: If the height is OK , there are three nuts at the bottom of the bracket just above the actuator shaft. With the bucket in the up position loosen those and let the bracket slide enough for the action to lock.
Old Dec 19, 2010 | 10:17 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
I'll tell you what it most likely is. There is a stop for the mechanize right in the middle of everything.
In the picture of mine what you can see is the bottom of the bolt that needs adjustment, it's in between the 4 springs. It has a hex bottom so you can adjust it from the end showing as the stopper end is hard to get to when in the car.
Old Dec 19, 2010 | 10:20 AM
PUNISHER VETTE
This one might help you see what it is as well.
Right in between the two springs. What you're looking at is the bottom of the bolt and the top is what is used as the stopper to keep the mechanize from locking too tight.
To Headlight locking mechanism help...
