Coil Spring Install
Old Dec 19, 2010 | 12:45 PM
C3Vettes.net's Avatar
C3Vettes.net
Default Coil Spring Install
Piece of cake in less than 1/2 hour. Set spring in frame and compress using BRANICK MODEL SCT-520 SPRING COMPRESSOR. Place floor jack under lower a-arm and use 2x4 to guide bottom spring into lower a-arm. Attach lower spindel and then jack up lower a-arm and attach upper a-arm.
Old Dec 19, 2010 | 05:34 PM
Timsride's Avatar
Timsride
Good job and quick too. it always feels great when You reach an accomplishment on Your car.
Old Dec 20, 2010 | 02:38 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I agree easy to do the only thing I do is tie the spring just in case it decides to fly out,Ron
Old Dec 20, 2010 | 04:59 PM
C3Vettes.net
The Branick compressor made all the difference in the world. Just ran it through the shock hole at the top of the mount. Why is it always so suprising when something is easy on these cars???
Old Dec 20, 2010 | 08:24 PM
7t3shark's Avatar
7t3shark
I second the recommendation to safety strap the spring. Met a guy years ago that was living proof of what can happen if it gets loose. He was prying a spring out of the A-arm pocket and thought the pressure had been released. When it popped out, took out his front teeth and put a hole in the concrete block wall. Ouch.
To Coil Spring Install
