Chain Hoist Experiences?
Old Dec 20, 2010 | 04:23 PM
ncvettes's Avatar
ncvettes
Default Chain Hoist Experiences?
I'm trying to decide which hoist or winch to use. I have an I-beam gantry with a manual trolley but not sure what to hang on it. All I've discovered so far is that the good hoists or winches are way too expensive, and the cheap ones are, well, cheap with limited single line hoisting capacity. I like the electric chain hoists, but there's that big $ issue again, so what about a manual chain hoist? Doesn't the chain get in the way? Seems like it would be yet another item to look after when pulling a body, for example. Let me hear your experiences, please.
Old Dec 20, 2010 | 04:39 PM
midyearvette's Avatar
midyearvette
yes the manual chains will get in the way but you get used to it
you could also use a heavy duty come along too.....good luck
Old Dec 20, 2010 | 09:31 PM
72LS1Vette's Avatar
72LS1Vette
A chain hoist will do the job. Throw some towels over the body to protect it and just be careful of where the chain falls.
Rick B.
Old Dec 20, 2010 | 09:37 PM
tfi racing's Avatar
tfi racing
Also beware of the battery,booster cables,sponge and bucket of water...
Old Dec 20, 2010 | 10:10 PM
Duane4238's Avatar
Duane4238
Lethal Weapon! Good movies.
Old Dec 21, 2010 | 01:17 AM
sly vette's Avatar
sly vette
I would have preferred to use a chain fall for my heavy lifting but I had limited height So I bought a cherrypicker instead. Still got the job done.
Which ever you choose...Patience is the key!
Old Dec 21, 2010 | 01:26 AM
leskinner's Avatar
leskinner
I have an electric hoist on a trolly and I-beam. It is made by "budget"
and is rated at 1/4 ton. It is about 35 years old but has never failed to lift anything including a 69 BB with tranny attached, the body off my
75, and the back half of a chevy station wagon. The only problem I have with it is that the speed is not variable. When you hit the "lift" switch you damn well better have everything disconnected that is supposed to be. Also, lowering a motor into the hole or body back on frame there is no finesse. Nice and convenient but sometimes scarey.
You would have more control with a manual chain hoist.
My $.02
Larry
Old Dec 21, 2010 | 08:46 AM
The Money Pit's Avatar
The Money Pit
When I went down that road of deciding what type lift to use, the all mighty dollar made my decision. I got this picker for less than an I beam would have cost, not to mention the beam trolley and chainfall or comealong,...none of which I had.
This is not the most heavy duty picker I've seen, but I've pulled the motor out of the Vette three times already, and even used it to lift my tractor off the floor to sharpen the blades....(Too lazy to drop the deck.)
For what it's worth I work alone, and the picker allows me to precisely lift and hold the motor exactly where I need it, so I can align bolt holes, etc.
Old Dec 21, 2010 | 10:07 AM
76stingracer's Avatar
76stingracer
The hand chain for a manual chain hoist can be shortened. I got tired of the chain hitting everything. The chain hoist now has a 1ft drop on the hand chain. It helps keep all that chain out of the way
Old Dec 21, 2010 | 11:10 AM
Solid LT1's Avatar
Solid LT1
I did my last motor install with a $60 Harbor Freight 2ton chain hoist so I didn't have to retrieve my cherry-picker for my freind's house and take up garage space I need. When I told him I was doing the motor installation he said: good you can come over and get your cherry-picker, my response: NO! Harbor Freight is making you store it for another year (finders-keepers)
Old Dec 21, 2010 | 11:21 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Can I ask how much you paid for the motor hoist, and where did you get it? Am about to start pulling my motor. Have the motor stand, need the hoist. Thanks . mj.
Old Dec 21, 2010 | 11:40 AM
Denpo's Avatar
Denpo
I used two cheap 1 ton chain hoist to lift my body, got them at the canadian equivalent of Harbor Freight, 40$ each. Worked like a charm.
http://forums.corvetteforum.com/c3-g...long-post.html
Old Dec 21, 2010 | 02:39 PM
ncvettes's Avatar
ncvettes
Here's a photo chop of my idea to get the chains out of the way. Still needs a pulley on the trolley and some trolley locking pins, but you get the idea. This can be moved to either side. Good-bad-ugly?
Old Dec 21, 2010 | 03:05 PM
jnb5101's Avatar
jnb5101
i don't think that lacing the chain thru a loop and then to the load will work. mount the chain hoist over the load, and then use a piece of pvc pipe as a tunnel for the control chain. run a bolt (or such) thru the pipe at the operators end so the chain can't slip out. that way the chain is always in the correct place, and it can't damage the car.
Old Dec 21, 2010 | 03:36 PM
mikejpss's Avatar
mikejpss
Old Dec 21, 2010 | 04:35 PM
The Money Pit
I found a local store that sold stuff like Harbor Freight, not sure what the name of the place was, but the whole deal was under $200. I used to rent one every time, and this one has paid for itself already.....
Old Dec 22, 2010 | 12:56 AM
1976 corvette's Avatar
1976 corvette
I use Harbor Freights 1 ton and haven't had any problems.
With the frame
Old Dec 22, 2010 | 02:40 AM
ncvettes's Avatar
ncvettes
I ordered a Jet 1-ton hoist. Although much pricier at $170, I believe the workmanship will compensate for it.
Old Dec 22, 2010 | 09:21 AM
MalibuVLX's Avatar
MalibuVLX
I use a one ton chain hoist from a I beam in my garage. And yes, the chain is pain the tail, but I usually have a friend around that will hold the chain or help keep it off the motor/car.
How did you shorten the chain or your hoist? I would love to do this, but not sure how to do it w/out a larger link in the chain. Weld up the link after you cut out the unwanted length.
To Chain Hoist Experiences?
