Fuel pump relay
Old Dec 22, 2010 | 12:36 PM
nastee383's Avatar
nastee383
Default Fuel pump relay
Does a relay die a slow death or is it sudden and permanant? My fuel pump started spitting and sputtering. It would not flow a steady stream. Sometimes the pressure would drop to zero and other times it would show 5-6 psi. At zero of course the car would die. Ay 5-6 psi it would run but it takes constant manipulation of the throttle to keep it running. I went to the back and listened to the pump when it was showing pressure and I can hear it sputtering. I replaced the fuel pump but the results are the same. I dropped the tank and made sure nothing was clogged, bent or kinked. my fuel line is -8an braided and the return line is the original metal fuel line. I made my own 1/2" pickup. I've been running this setup for at least 8 years with no problems. Now it seems to be slowly dying. Any theories on what's going on?
Old Dec 22, 2010 | 12:43 PM
mrvette's Avatar
mrvette
Sounds electrical,and yes a bad ground or relay can cause that troubles, and you need hang a VMeter across the pump to find what is the troubles...tap the relay with a screwdriver handle and see if it acts up....
