Rear Spindle Support
Old Dec 22, 2010 | 05:27 PM
kernalclink's Avatar
kernalclink
Default Rear Spindle Support
Hi,
Can anybody tell me what the difference is between the left and right spindle support? The reason I'm asking is that my '73 that I am restoring, according to the part number, has two left side spindle supports. In other words, there is a left hand spindle support installed on the right side.
I can't really figure out what the difference would be since the spindle support seems fairly semetrical.
Thanks in advance....
Old Dec 22, 2010 | 05:59 PM
mds3013's Avatar
mds3013
Where the lower shock mount passes through support and strut rod the front hole is round, the rear hole is D shaped with a flat that matches the shock mount. mike...
Old Dec 22, 2010 | 06:10 PM
kernalclink
That makes sense...
Thanks for the reply....
Old Dec 23, 2010 | 09:26 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
If you need another right hand I have a few floating around the shop. Let me know.
Andrew
800-442-0335
Old Dec 23, 2010 | 02:46 PM
spinadog's Avatar
spinadog
Better get it right and check carefully the support. I purchased one from Willcox where the flat of the D was machined 'perfectly' at 90 degrees - wrong.
Willcox swapped it for me almost 4 months later. Great customer service!
Old Dec 26, 2010 | 11:20 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
On your 73 the same casting was used left and right and the difference as mentioned above was the machine process of the D in the lower section of the support. So in your case both supports carry the same part casting number 348103.
Happy Holiday's,
Willcox
Old Dec 26, 2010 | 04:25 PM
kernalclink
Thanks for the answers....
Does anyone have the torque specs for the rear bearing support studs?
Old Dec 26, 2010 | 09:56 PM
0Willcox Corvette
Former Vendor
I don't remember and the only shop manual I have here is the one for 63. Different size bolts so it won't be the same. (63-64 used a different bolt).
Maybe someone else will pop in for you.
Old Dec 27, 2010 | 10:55 AM
kernalclink
I have a manual... the only thing I can find that looks like it could be it is a line that says...
"Drive Spindle Support to Torque Arm" 30 1b-ft
but I don't think that sounds like it...
Old Dec 27, 2010 | 02:08 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Willcox Corvette
On your 73 the same casting was used left and right and the difference as mentioned above was the machine process of the D in the lower section of the support. So in your case both supports carry the same part casting number 348103. ...
My illustrated Corvette parts catalogue shows 348103 as the left and 348104 as the right, 68-82 all.
Old Jan 3, 2011 | 01:18 PM
0Willcox Corvette
Former Vendor
Mike, You are correct, the support part numbers were 103-104 on the boxes but the casting number were the same and the part was just milled differently.
It gets kind of Tricky id'ing left from right for sure. It was kind of like the spindles for the early c1 cars and the spindles for the 49-52 passenger cars. They carried the same casting number but had a different cut to them and a different part number. To tell the difference apart you had to look for a daub of yellow paint on them.
To Rear Spindle Support
