Needing Front End Rebuild Kit?
Old Apr 8, 2002 | 08:40 AM
shamby's Avatar
shamby
Default Needing Front End Rebuild Kit?
I am needing to rebuild the front end of my 77. Any sugestions on who to purchase the kit from?
Poly or rubber?
Old Apr 8, 2002 | 09:35 AM
Vettesic's Avatar
Vettesic
Default Re: Needing Front End Rebuild Kit? (shamby)
Shamby,
I bought the Eckler's kit. Yes the poly is the way to go. A bit more $ though. Keep in mind that the bushings in the upper and lower control arms have to be shop-pressed out and back in. Unless you have acess to that equipment. Some of the local vette shops im my area sell the control arms already resto-ed. Cleaned, degreased, painted with the new poly bushings installed with your exchanged control arms. Check with the shops in your local, if that's the way you want to go. Just a consideration for you. Good Luck, L8TER, Paul.
Old Apr 8, 2002 | 10:22 AM
terryrudy's Avatar
terryrudy
I got my front end rebuild kit from Vette Brakes. I got Poly - but be warned they may squeak unless you use some nice grease (I got some Marine Grease from hardware store and very few squeaks). I drilled out the old rubber bushings myself and then the poly just popped in - didn't need to use a press. I think with Rubber, though, you will need a press.
Be sure to check your "rag joint" as well. I rebuild my front end and still was unsatisfied. Turned out I needed to replace rag joint and tighten steering box. Jim Shea wrote up some nice procedures for this which you can find on corvettefaq.com.
good luck!
-terry
Old Apr 8, 2002 | 10:49 AM
shamby's Avatar
shamby
Default Re: Needing Front End Rebuild Kit? (terryrudy)
THanks for the info. Stupid question, how can you tell if your front end needs to be rebuilt??
Old Apr 8, 2002 | 11:03 AM
terryrudy's Avatar
terryrudy
What is the condition of the front end bushings? Are they cracked, split, chunks missing?
If they look OK, then first just try working on the steering. Also the shocks. I found that nice shocks made a huge difference to drive quality as well.
good luck
-terry
[Modified by terryrudy, 7:04 AM 4/8/2002]
Old Apr 8, 2002 | 11:14 AM
shamby's Avatar
shamby
They are all cracked, plus I have the body of the off the frame and I figured now would be a good time to do it.
To Needing Front End Rebuild Kit?
