Engine run on
Old Apr 8, 2002 | 09:42 AM
1LE's Avatar
1LE
Default Engine run on
Changed pulgs and plug wires the past weekend, now when I turn the key off, I have a little engine run on. Just for a second or two. Nothing else on the car has been changed. I've checked the timeing, and its set at 9-10 deg. Should I back it off to 8 ?
Old Apr 8, 2002 | 09:48 AM
xfactor974's Avatar
xfactor974
Default Re: Engine run on (1LE)
Maybe you're idleing too high and it's pulling the timing in. Then when you shut off the car you have some advance in and the car putts for a sec. Check the idle speed and then look at when your advance comes in.
