Tachometer Question
Old Apr 8, 2002 | 10:25 AM
Andrew's Avatar
Andrew
Default Tachometer Question
I just received a new circuit board for my Tach. I have the tach out and the old board off. Before I install the new board, I was wanting to know if I need to "reset" anything or is there anything that I need to be aware of?
Old Apr 8, 2002 | 10:29 AM
mrvette's Avatar
mrvette
Default Re: Tachometer Question (Andrew)
IT's plug and go....nothing to do,....just hook it up...
check that tach filter....see other threads...do a search here....
Old Apr 8, 2002 | 06:20 PM
bl75vette's Avatar
bl75vette
Just replaced mine and the instructions had me run a positive and negative supply from the battery to the tach to reset it. I had to remove the needle carefully and while it was connected to the battery re-position the needle so it read 0. At first I was afraid to do it but it worked as instructed. By the way I bought mine from RIKS who in turn buys from a guy in the woods of Penn.
To Tachometer Question
