mechanical secondaries vs vacuum secondaries
Old Dec 27, 2010 | 12:28 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Nothing is going to hurt the trans. If you want it simple and just bolt it on and forget it..then stick the vacuum one on there.
Just don't be surprised when your buddy buys a Dp and spends a couple of hours at the most making it perfect and runs off and leaves you!
JIM
Old Dec 27, 2010 | 06:47 AM
gingerbreadman1977's Avatar
gingerbreadman1977
like i mentioned earlier and like alot of others said your border line and both will work just fine.....but upgrade your stall to a 2500 or go to a larger cam etc and that DP will pay big dividends.
i have just one more thing to say , if i had just 1 dollar for every time i heard someone with a vacum secondary carb say " IM NOT SURE IF MY SECONDARIES ARE WORKING'".....i would be a rich man by now.
Old Dec 27, 2010 | 07:40 AM
shamby's Avatar
shamby
I don't think my secondaries! Really, I don't believe they are. I tried the paper clip trick and nothing. If I could go back I'd purshase the manual then you don't have to worry about the stupid vacuum hose. Good luck
Old Dec 27, 2010 | 07:51 AM
jb78L-82's Avatar
jb78L-82
On Holleys with vacuum secondaries, just do a before and after road test. All you have to do is to remove the vacuum hose and plug it that goes to the secondary vacuum diaphram-and the secondaries will NOT open. Is this hard???
Old Dec 27, 2010 | 12:31 PM
DRIVESHAFT's Avatar
DRIVESHAFT
The vacuum port is internal. There is no hose.
Old Dec 27, 2010 | 02:31 PM
427Hotrod's Avatar
427Hotrod
Back in my *street racing* days...I often would completely remove the little throttle link between the primary and secondaries that actually holds the secondaries closed and would put it in my pocket. That convinced most folks that didn't know how they worked that I'd only be running on *2bbls*. Just feather into it...and a little down track go WOT and the secondaries flopped right open. Folks were just flat amazed how fast a 2BBL could run!@!
He he he......
JIM
Old Dec 27, 2010 | 02:57 PM
jb78L-82's Avatar
jb78L-82
You are correct-just remove the c clip from the actuator rod on the vacuum diaphram and the secondaries will become inoperative. My mistake!
Old Dec 27, 2010 | 03:09 PM
baxsom's Avatar
baxsom
just keep going down in spring tension on the secondaries and when you feel it bog it is opening too soon.
then go back up one.
once open a 750 vacuum and a 750DP with the same jets are going to flow the same air and fuel.
Old Dec 27, 2010 | 03:57 PM
JE Caudle's Avatar
JE Caudle
Default Vacuum vs Mechanical
Originally Posted by jnb5101
there's nothing to be gained with mechanical secondaries except for a "bog". the vacuum's will give the engine all the air it can use.
I have a Holley 750 double pumper on a ZZ4 and have NO bog at all.
If you run into bog, your carb is too large for your engine or you do not
have it set up correctly.
HillBilly John...
Old Dec 27, 2010 | 04:22 PM
baxsom's Avatar
baxsom
HillBilly John...
what transmission do you have?
Old Dec 27, 2010 | 04:36 PM
JE Caudle's Avatar
JE Caudle
4 Speed
HillBilly John...
Old Dec 27, 2010 | 05:02 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
Several years ago I put a 670 Street Avenger on my stock (with the exception of a 71 LT1 intake) 69 350/350 and never liked the way the secondary's worked. At least the springs were easy to change.
I replaced it with a 650 DP and couldn't be happier. As others have mentioned it is nice to be able to control the secondary action although I realize it is ultimately no faster.
FWIW I put the electric choke and linkage from the 670 SA on the 650 DP and it worked out great. The fast idle works perfectly and it starts instantly cold or hot.
I also used a reproduction LT1 fuel line and fuel block and it looks factory.
Old Dec 27, 2010 | 05:46 PM
  #33
baxsom's Avatar
baxsom
4 Speed
HillBilly John...
I was just wondering. Usually the WOT bog only happens on an auto with a double pumper
Old Dec 27, 2010 | 05:54 PM
  #34
Vette Cruz-in's Avatar
Vette Cruz-in
It sounds like many people on the forum have had good luck with 650 or 750 DP's on 4 speed cars - which is what I expected - but I have not heard many who have a DP with an auto - anyone out there with an auto and a DP carb - I'm interested in hearing from you.....
Old Dec 27, 2010 | 06:28 PM
  #35
toddalin's Avatar
toddalin
Not if you floor it at less than the RPM that the secondaries open at (e.g., 2,000 RPM in 4th).
Old Dec 27, 2010 | 07:06 PM
  #36
gingerbreadman1977
i have a demon 750 dp on both these motors..
1-10.5 350, roller cam,air gap,fastburn heads,3000 stall....no bog
2-11.1 383,hydraulic cam,eliminator,fastburn heads,2500 stall....no bog except in pants
with dp you KNOW that fuel is going in !!
Old Dec 27, 2010 | 07:14 PM
  #37
Les's Avatar
Les
Go back to post #17 on page 1 of this thread.
To mechanical secondaries vs vacuum secondaries
Old Dec 27, 2010 | 07:22 PM
  #38
427Hotrod's Avatar
427Hotrod
It's all in the tune. I ran a DP on a 396 Nova with a single plane manifold and 3.08 gears and a 2200 converter. I actually played with it to NOT be so responsive and get right on the borderline of bogging so I could get it to hook decent on street tires.
It's all in the accelerator pump tuning and ignition timing.
Again, VS are safe, I just don't like the way they drive as much.
JIM
Old Dec 27, 2010 | 08:13 PM
  #39
v2racing's Avatar
v2racing
The build in my signature is running a highly modified double pumper. This set up was in my 80 Vette with 3.07 gears and it ran superb. If you floored it from idle it would just turn the tires into smoke, no bog. It also got 22 MPG on the interstate. I spent time tuning every circuit in the carb and tuning the distributor mechanical and vacuum advance.
The engine that came in the 75 is a milder 406 making 545 hp with a Demon 750 DP. As it came to me, it did not bog. It also would just roast the tires when you stomped it. It got lousy gas mileage though. When this engine goes into my 64 SS I will tune it so it performs excellent and gets good mileage.
If a DP carb is matched to the build and is tuned properly, it will not bog, it will run great, and you can get good mileage. I've ran many DP's with autos.
Old Dec 27, 2010 | 09:09 PM
  #40
DRIVESHAFT's Avatar
DRIVESHAFT
I've run a 750 dp on a 355 with a 2500 converter with no troubles or bogs.
