I just removed the 3.08's from my parts car so now I have a spare and I am thinking of getting 3.55 or 3.70 now that I can send one away and still drive my car while I wait (also 3.08).
My question is where is a good place to swap and get the new ones, or should I get a local shop to change it for me. I am looking for a fair price on a good set up.
Any Ideas. :cheers:
I've seen some pretty cheap deals on eBay :D
...or you can get a shop to change out the gears.
Carriers are different for a 3:08 & 3:70 (not sure about the 3:55)... so you'll need to order a 'thickened' ring gear to make it work with a 'higher' ratio. :)
What is different about the carrier.
and also I thought that you needed a new ring and pinion gear any way
I have seen pin and ring gears sold from summit and I thought that was all I need assuming I get a shop to change them out. :confused:
The carrier is the same for 3.08 and 3.70. Its a series 3 and is good up to 3.90. Series 4 for anything higher unless you use a spacer. You're not probably interested in it but I have a near new 4:11 set with a spacer and the proper bolts. I live just down the way from you on Gabriola.
bob
Hey bob
check out my sig and give me an email with what you want for the 4.11
and would it bolt right in.
This summer we should get togeather. may be in the show in Nanaimo in July.
And I don't supose you would know which spedo gear I would need for my TH350 with 235/60/15
Thanks in advance. :cheers:
