poor choice on rear
Old Dec 29, 2010 | 12:33 AM
terl30's Avatar
terl30
Originally Posted by 427Hotrod
That thing was broken in about 5 minutes after you cranked it. No different than throwing a new motor on the dyno. It's either right or it's not.
I ran 4.56's in my old Camaro with a 427 and both a T-400 w/4500 converter and a 4 speed. Pretty much lived at 4000-4500 rpm all the time...but it never hurt it. I still have the motor after 20+ years!
Just depends on how much highway driving you do and how annoying it is.
What did you do to the zz4 to get the 420 HP?
If the planets are all aligned properly 420Hp *can* get you high 11's@117 mph or so hauling 3300 lbs. 117 MPH with a 4.56 gear and a 28" tire is going to take a little over 7000 RPM at the line if I guesstimate the converter slips 8% or so maybe?
But since we're talking a real street car here with accessories, exhaust etc, you won't likely get that much MPH ...so the peak RPM will be a lot lower too. But it's going to need to be happy to 6500 rpm for sure.
JIM
Well actually it was a zz4 short block/gmpp vortech heads 64cc/edelbrock perfmore rpm cam .488lift/edelbrock rpm air gap/hooker super comp headers/comp cams full roller rockers 1.6/edelbrock 750 carb/mallory tach drive hei dist/tci street fighter th400 with 2600 stall(i know i need 3k plus) edelbrock told me with 64cc heads i should have 420hp i ordered the performer rpm total power package.
Old Dec 29, 2010 | 05:18 PM
jdinwidd's Avatar
jdinwidd
2nd Gear
Default Poor Rear End Choice
Let's see if we can work this out. I will PM you with my info.
