no brake pedal pressure
Old Apr 8, 2002 | 01:29 PM
Todbo's Avatar
Todbo
Default no brake pedal pressure
trying to bleed my brakes yesterday and no pressure at the pedal , I couldn't pump any fluid out of the rear calipers , I removed the master cylinder and cleaned it , also manually pushed the pump , maybe one pump out of four would shoot some fluid out of master cyl. Does that sound like a bad MC, or maybe something else? thanks
Old Apr 8, 2002 | 02:00 PM
hdpete98's Avatar
hdpete98
Default Re: no brake pedal pressure (Todbo)
Did you "bench bleed" the master cylinder? If not, that could be the problem.
