Locking, nonlocking, poly.... Which mount?
Old Dec 28, 2010 | 09:44 AM
AvRog's Avatar
AvRog
Default Locking, nonlocking, poly.... Which mount?
What type of engine mount should I order for my 69 BB? I am concerned most with vibration reduction/comfort. Also once the motor is in position I want it never to migrate in the mount due to torque.
Old Dec 28, 2010 | 10:01 AM
midyearvette's Avatar
midyearvette
energy suspension mounts will hold it solid and insulate vibration however they are subject to heat especially on the driver side and some "snot" will melt and drip off of the mount after a few thousand miles but no ill effects.....
Old Dec 29, 2010 | 08:02 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
We have also had good luck with the poly mounts, and we've been using Prothane for a while.
Old Dec 29, 2010 | 09:41 AM
Mike Ward's Avatar
Mike Ward
The standard locking mounts from GM work just fine.............
Old Dec 29, 2010 | 09:27 PM
vettehardt's Avatar
vettehardt
You definitely want a locking mount. IT will keep the engine from coming up if/when the mount breaks. Weather you choose poly or rubber is up to you.
To Locking, nonlocking, poly.... Which mount?
