Brake cooling Q's
Old Dec 28, 2010 | 08:12 PM
vette427-sbc's Avatar
vette427-sbc
Default Brake cooling Q's
When ducting air to the brakes, do you want all of the air going to the rotor veins? Is it better/worse to cool the rotor surface as well? Heres where I am as of now:
Going to weld this pipe to the dust cover (cutting the rest of it away), and weld another piece on the inside to direct it to the veins. Heres where my question comes into play- While more than half of the pipe will be directed into the veins, the outer half will be blowing air on the rotor face. Is this acceptable?
Old Dec 28, 2010 | 09:27 PM
GUSTO14's Avatar
GUSTO14
Direct as much of the air at the center of the rotor as possible and let the vanes (of the spinning rotor) do the work.
Good luck... GUSTO
Old Dec 28, 2010 | 09:35 PM
PeteZO6's Avatar
PeteZO6
I haven't experienced it myself, but all the technical articles I have read on the subject warn that cooling one side of a rotor more than the other side can cause the rotor to warp towards the cool side. You'd be better off to seal the output of your duct to the center of the rotor so all the cooling air goes out through the cooling vents.
Pete
Old Dec 28, 2010 | 09:46 PM
vette427-sbc
Pete
That is what I had read too. What I dont understand is why the rotor face is different than the vanes in terms of cooling. If the rotor is spinning, then an equal amount of the rotor is being fed fresh air. Only one side of the vanes getting air, so why would it matter if the rotor face was getting the same? I just finished cutting the dust shield to fit the pipe... I have the pipe as close to the spindle as I can get it:
Old Dec 28, 2010 | 10:14 PM
gkull's Avatar
gkull
Oval the end to get as much as you can towards the center. I have the 13 inch aluminum hat Wilwoods and I have removed my ducting for street driving. I need some temp in my pads to really make them work and they are just to cold on the street.
Old Dec 29, 2010 | 07:58 PM
PeteZO6's Avatar
PeteZO6
If the cooling duct directs the air to only the center of the rotor and it enters the cooling slots, the air will be forced outward and cool both sides equally. If you aim the duct to cool one side of the rotor, that side will expand less than the hotter side. You'll get a saucer shaped rotor. Not good.
As gkull says oval the end of the duct. That will ensure that air won't cool just one side of the rotor.
Pete
Old Dec 29, 2010 | 10:40 PM
vette427-sbc
Pete
I get it now... I kept thinking warping like a pulsing through the brake pedal. The saucer shape makes sense. Ill oval the pipe to feed only the vanes
Old Dec 30, 2010 | 09:34 PM
vette427-sbc
Just a quick update:
I ovaled the pipe to cool only the vanes and welded it to the dust shield. (still need to clean up my welds and trim the dust shield better)
Going to clearance the pipe-to-rotor a bit more
Old Dec 31, 2010 | 10:55 AM
gkull's Avatar
gkull
I was thinking if you took the tube and just put one end in a vise and oval it. That way you still have one round end for the ducting flex air line.
But what ever works is the most important
Old Dec 31, 2010 | 03:31 PM
vette427-sbc
Thats exactly what I did... The pipe wouldnt stay completely round on the other end. Its not as far off from round as it looks. Should work ok, plus it gives me more room next to the spindle.
To Brake cooling Q's
