Replacing U joints
Old Apr 8, 2002 | 05:48 PM
jerryjfunk's Avatar
jerryjfunk
Default Replacing U joints
I unbolted the driver side, took it out, and replaced both the inner and outer joints (I just noticed the other thread... I used non-greaseable Bruteforce). Then I unbolted the other side. It won't come out.
My dad and I pulled on that !@#$er for an hour, and it won't budge. Is there something I'm missing here? The driver side just slid right out.
Thanks guys,
Jerry
Old Apr 8, 2002 | 06:16 PM
verskel's Avatar
verskel
Default Re: Replacing U joints (jerryjfunk)
No problems with mine - :confused:
...just a little dirt / rust :chevy
Old Apr 8, 2002 | 10:28 PM
GTR1999's Avatar
GTR1999
You have the joints disconnected and still can't get the 1/2 shaft out? Are you sure you have all the bolts out? Did you try tapping it with a mallet?
Gary
Old Apr 9, 2002 | 12:21 AM
jerryjfunk's Avatar
jerryjfunk
No, on the passenger side, I don't have the joints out. I took all of the bolts out of the shaft, and that end came out. But it won't pull out; it feels like there is something locking it in.
I guess I'll just tap on it and pull some more tomorrow morning!
Thanks,
Jerry
Old Apr 9, 2002 | 12:42 AM
jamiejamison's Avatar
jamiejamison
Jerry, did you turn the strut rod cams to force the trailing arms outwards? This should do the trick. Mark the position of the strut rod cams so that you can return them to their position for correct alignment. LOL jamie
Old Apr 9, 2002 | 02:10 PM
jerryjfunk's Avatar
jerryjfunk
Default Re: Replacing U joints (jamiejamison)
I got it off this morning, after a little prying. Then I opened the box... and she gave me the wrong U JOINT!! :mad Back to the store I went...
Thanks for all your help guys, I really appreciate it!
Jerry
To Replacing U joints
