C3 front spindle nut torque
Old Dec 30, 2010 | 06:42 AM
mach172's Avatar
mach172
4th Gear
Default C3 front spindle nut torque
Does anybody know the correct procedure for tightening/torque front spindle nuts of my '72 ? My assembly manual is not covering this.
Old Dec 30, 2010 | 08:01 AM
Chuck72's Avatar
Chuck72
The procedure is covered on detail on page 3-4 of your service manual. Basically, clean, inspect, repack brgs, assemble, snug up to preload, only to seat brgs, back nut off to drop cotter pin in next available hole in spindle. NO PRELOAD ON BRGS!!
Have a safe new year!
Regards,
Chuck
Old Dec 31, 2010 | 02:57 AM
my 76 ray's Avatar
my 76 ray
The manual for my '76 says to torque to 12 ft/lb while turning the wheel. Then back off the nut to the next hole and insert the cotter pin. If you don't have a torque wrench you can just tighten until the nut is just snug while turning the wheel before backing off the nut.
To C3 front spindle nut torque
