Seat belts
Old Dec 30, 2010 | 04:35 PM
cm2dinger's Avatar
cm2dinger
Default Seat belts
My '69 coup has original lap belts that dont work at all. The belts are frayed and the buckles dont clip. So its time to upgrade i want to put in shoulder belts but dont know whare to bolt up the shoulder section and also wonder it there is anything that i can pull from a junk yard that would bolt up at least on the floor side of the set up. thanks in advance for yalls help.
Dinger
Old Dec 30, 2010 | 08:41 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
The mounting hole is already in the rear for the shoulder mount bolt. There is a nut plate rivited to the vertical wall of the fenderwell. If you pull the carpet out of the way, you will see a plastic plug in the bolt hole.
As for the belts, a rear seat set from a gen. 4 camaro or firebird is the common bolt in salvage yard swap. Do a search here for seat belts and you will have hours of reading.
Old Dec 31, 2010 | 12:30 AM
cm2dinger's Avatar
cm2dinger
thank you much first time i seached i got more c4 and up or wtb or fs stuff thanks for the info and ill search it again.
Old Dec 31, 2010 | 02:01 AM
vettehardt's Avatar
vettehardt
Try your search just in the C3 tech section. You should find quite a few posts on the subject
I have put the gen 4 belts in my 76. I got a set of belts from a firebird since that was the only car that came with black belts. I suggest getting something to keep the belts up on your shoulder. I installed a set of belt loops from a 3rd gen camaro onto the side of my 80 style seats. It keeps the belt from slipping off of your shoulder or just being in the wrong position to properly restrain you in a crash. Those loops are gray right now, but I will be dying them shortly.
In my 73, I have a 5 point harness mounted on the vertical bulkhead behind the seat. A racing style seat will be going in next. Of course I only use that car to autocross with.
Old Jan 1, 2011 | 08:43 AM
redwingvette's Avatar
redwingvette
I used the F-body belts in my 73 which should be the same for your 69.
I bought them off ebay for $.99 plus $8 shipping. I was the only bidder.
install
To Seat belts
