using an external fuel source
Old Dec 31, 2010 | 07:28 PM
bucksy99's Avatar
bucksy99
Default using an external fuel source
I need to run my 75 from an external fuel source to figure out if the engine runs on its own. It has not been started in a while and the tank is probably is full of rust.
I connected the fuel line from the pump to a gas can but can't get any fuel to squirt out of the steel pipe. I know the pump works. I got it to pump some gas out of the tank. Now I can't get anything out of a gas can which is odd. Could it be plugged up or does the vapor return line that is still connected to the tank have anything to do with it ?
Thanks for any input.
Old Dec 31, 2010 | 08:50 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
You probably have air in the line and or gravity is working against you. Try raising your aux tank off the ground (bench/chair) and bleeding the line.
HTH,
Rob
