77 Vette Part Identification
Old Jan 2, 2011 | 08:09 AM
tommyleea's Avatar
tommyleea
Found under console
http://photo1.walgreens.com/walgreen...AME=walgreens/
Old Jan 3, 2011 | 11:45 AM
RaymondD's Avatar
RaymondD
It plugs into one of the gauges in the center console, I just can't remember which one. My first thought is the fuel gauge for a low fuel warning but, I could be wrong.
Old Jan 3, 2011 | 06:50 PM
mds3013's Avatar
mds3013
Correct. Low fuel warning light circuit board. mike...
Old Jan 3, 2011 | 06:56 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
yep, seems a lot of them end up on the floor!
Old Jan 3, 2011 | 08:45 PM
tommyleea's Avatar
tommyleea
Wow, Thanks. I didn't even know I had that indicator.
Old Jan 3, 2011 | 08:58 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Is this for a '77. I didn't know I had a low fuel indicator.
Old Jan 3, 2011 | 09:04 PM
tommyleea's Avatar
tommyleea
Yes, it is a 77.
Old Jan 3, 2011 | 09:06 PM
tommyleea's Avatar
tommyleea
I don't see my picture there anymore.
Old Jan 3, 2011 | 09:13 PM
mds3013's Avatar
mds3013
I do not know if all '77s had them. My car has the convience package where the interior lights stay on for awhile after you close the door. The low fuel warning light is the upper right light on center cluster. You might have to use a flashlight, from the front, to make it show up. Tommy, I can still access your pic. That board will have a light socket on the reverse that twists and locks thru circuit board into socket behind light window. mike...
Old Jan 3, 2011 | 09:16 PM
BPHORSEGUY's Avatar
BPHORSEGUY
I do not if all '77s had them. My car has the convience package where the interior lights stay on for awhile after you close the door. The low fuel warning light is the upper right light on center cluster. You might have to use a flashlight, from the front, to make it show up. Tommy, I can still access your pic. That board will have a light socket on the reverse that twists and locks thru circuit board into socket behind light window. mike...
Thanks mds, I know I do not have the convenience pkg. and I have never seen a low fuel light.
Old Jan 3, 2011 | 09:25 PM
tommyleea's Avatar
tommyleea
Thanks. There is a bulb in the board. I will check that out tomorrow. I do have the convenience package also.
Old Jan 3, 2011 | 09:34 PM
mds3013's Avatar
mds3013
Tommy. These things are notorious for failing. I think mine is currently not working. Willcox has a great tutorial on checking them. I will see if I can get you a link. mike...
http://willcoxcorvette.com/instructi..._TESTING_2.pdf
Old Jan 3, 2011 | 09:41 PM
tommyleea's Avatar
tommyleea
To 77 Vette Part Identification
