Brodix Heads - Temp Sensor??
Old Jan 2, 2011 | 09:50 AM
DO2G's Avatar
DO2G
Default Brodix Heads - Temp Sensor??
I just purchased a pair of Brodix IK180 heads. Any thoughts on how to hook up the temp sensor since there is no provision in the heads?
I have a Edelbrock 2101 Intake.
Old Jan 2, 2011 | 10:16 AM
Grumpy 427's Avatar
Grumpy 427
your only option is the hole in the intake on front.
Old Jan 2, 2011 | 11:12 AM
redman76's Avatar
redman76
St. Jude Donor '09
That's what I had to do with my Brodix heads. I have the RPM Q-Jet intake.
Old Jan 2, 2011 | 01:29 PM
DO2G's Avatar
DO2G
Anyone know if the stock sensor will fit in the Edelbrock 2101? If not, what size do I need?
Old Jan 2, 2011 | 01:46 PM
Grumpy 427's Avatar
Grumpy 427
Not sure but you can get plumbing adapters that will work.
Old Jan 2, 2011 | 01:50 PM
Rebelrob's Avatar
Rebelrob
Same issue with AFR heads. Had to use the intake. Yes to what Grumpy said. Try and see if your original will fit , if not an adapter will be needed.
Old Jan 2, 2011 | 04:42 PM
mvette76's Avatar
mvette76
drill&tap thats what i did on my dart heads! 1/2" npt tap
Old Jan 2, 2011 | 09:07 PM
bluegtp's Avatar
bluegtp
I have the ik200....I just put in the intake.
Old Jan 2, 2011 | 09:26 PM
Grumpy 427's Avatar
Grumpy 427
Thats just sickening. lolol how the heck do you keep it so clean?
Old Jan 3, 2011 | 03:04 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Exactly what I did ....
On my AFR's I used an adapter to mount the OEM switch in the head, and use the same wire that it always had going to it. For the two switches that turn on the SPAL fans individually, I used intake manifold locations for both.
Old Jan 3, 2011 | 09:31 AM
DO2G's Avatar
DO2G
Do you have a photo? Just curious what it looks like...
Old Jan 3, 2011 | 09:34 AM
DO2G's Avatar
DO2G
Does it matter what side of the intake the sensor is mounted?
Old Jan 3, 2011 | 10:14 AM
682XLR8's Avatar
682XLR8
Did this on my IK200's
Or you can take the head to a shop and have it done if you don't have the tools to do it.
Old Jan 3, 2011 | 02:19 PM
DO2G's Avatar
DO2G
Where does the hole get drilled? Is there a drawing that I could give to a machine shop?
Old Jan 3, 2011 | 09:50 PM
682XLR8's Avatar
682XLR8
Select the head that will be on the driver side. Check out the machined surface for the exhaust manifold, and note that between ports 1 and 3 there is a half-round area cast into the head, and machined off on the surface like the surrounding area. That is where you drill & tap. Make sure whatever headers you use will clear(shouldn't be a problem, but check anyway)
Old Jan 4, 2011 | 12:27 PM
DO2G's Avatar
DO2G
Perfect...thank you
To Brodix Heads - Temp Sensor??
