Headers and Horsepower
Old Apr 8, 2002 | 11:08 PM
Scudd's Avatar
Scudd
Default Headers and Horsepower
Does anyone have an idea how much horsepower could be gained by adding headers to a mid-70s vette?
Old Apr 8, 2002 | 11:10 PM
Dr_stingray's Avatar
Dr_stingray
Default Re: Headers and Horsepower (Scudd)
well im no expert, but i think around 20-25 hp!
Old Apr 8, 2002 | 11:16 PM
SBR's Avatar
SBR
Default Re: Headers and Horsepower (Dr_stingray)
I would guess around 20hp. Remember that the more radical an engine gets the greater the gain is with headers.
Old Apr 8, 2002 | 11:20 PM
gdh's Avatar
gdh
Hard question to answer as it depends on which ones ie. 1 5/8 vs 1 3/4" , the intake that you have as well as the carb and flow rate of your heads. I have been reading the posts about this for a few years now and if I have learned anything it is that performance gain is a never ending search for more, and that you really have to sit down with a pen and paper and put the whole puzzle together within the budget that you can afford.
Old Apr 10, 2002 | 11:26 AM
fontking1a's Avatar
fontking1a
There is no definite answer. Anything you do to IMPROVE breathing will yield more efficiency and more horsepower. How much....do it and see. Also, all headers aren't the same. If they are not made correctly, you could have some problems. The tubing should be equal length and the diameter should be within certain measurements. Too big....or too small isn't a "good thing". Also, be careful on the muffler you select. If you add a set of great headers and a crummy overly restrictive muffler...you've wasted your time and money. Use a K&N air filter while you're at it and you will be surprised at how much bang you got for your buck.
Old Apr 10, 2002 | 11:42 AM
Fevre's Avatar
Fevre
Default Re: Headers and Horsepower (fontking1a)
Get some extra jets cuz you will need to play with the jetting after header installation, will run lean if you don't change em.
Old Apr 10, 2002 | 02:43 PM
Tominator's Avatar
Tominator
It sounds like you may have a y pipe going to the back. If you put on headers and run dualies you will notice a difference. Plus it will sound :cool:
To Headers and Horsepower
