Cross drilled rotors?????
Old Jan 3, 2011 | 01:04 PM
GT's 78's Avatar
GT's 78
Default Cross drilled rotors?????
Any personal experiences of anybody using cross drilled rotors? I was just wondering if there was a noticeable difference in brake performance with a cross drilled rotor v/s stock rotors.
Old Jan 3, 2011 | 01:11 PM
Belgian1979vette's Avatar
Belgian1979vette
I believe its mostly for use with metallic brake pads to get rid of gas built up between the pad and rotor, but that's as much as i know about it.
Old Jan 3, 2011 | 01:19 PM
Mike Ward's Avatar
Mike Ward
Oh no not again.
Old Jan 3, 2011 | 01:24 PM
VonDutch's Avatar
VonDutch
I have brembo's and I like them alot
Also they look really nice
For the track you can run solid Brembo Rotors
Old Jan 3, 2011 | 02:49 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Save your money. You only need cross drilled rotors when you are in to high speed, high brake heat applications. Most of us never get brake temperatures high enough to actually make use of the function of cross drilled rotors.
If you are autocrossing or road course racing, you could make use of them.
Old Jan 3, 2011 | 03:14 PM
Gordonm's Avatar
Gordonm
I have them. Are they needed? No. Will I ever need them, probably not. I needed new rotors and these looked a lot better but I have seen no difference in perfromance. Looks Yes. Peformance, not in 99% of the driving done here.
Old Jan 3, 2011 | 03:17 PM
crf311's Avatar
crf311
Mostly for show on the street. You will get some performance if you do road racing or autocross events.
Old Jan 3, 2011 | 06:32 PM
GT's 78's Avatar
GT's 78
Originally Posted by Mike Ward
Oh no not again.
Next time dont waste my time or yours with your meaningless comment!
Old Jan 3, 2011 | 07:15 PM
Paul L's Avatar
Paul L
A normal GM, non-Chinese, rotor will do the job for 100,000 miles for street driving.
Old Jan 3, 2011 | 07:38 PM
Mike Ward's Avatar
Mike Ward
Please do a search- you'll see that this same question has been asked many many times over and usually leads into a steep downwards spiral that gets locked by the mods.
Hence the 'not again' Did you miss the smiley? ->
GM's own research (I've got the technical papers) concluded that there's no advantage to drilled or slotted rotors on a street driven car.
Old Jan 3, 2011 | 07:47 PM
vettehardt's Avatar
vettehardt
I agree that Drilled rotors are of no performance advantage. They are only for looks on cars with open spoke designed wheels. Even in a racing application, drilled rotors do not help you. The drilled and sloted rotros were designed to help gas from the old organic pads that builds up between the pads and rotor. With todays brake pads, there isn't much gas that will build up on your pads to need a way to get it out. Most drilled rotors will crack between the holes when used for racing due to the high heat. Most of your top level racing series (ALMS, Grand Am, Trans Am, WC, NASCAR, etc) only use sloted rotors.
Save your money and just put solid rotors on unless you like the looks of drilled rotors behind your wheels.
Old Jan 3, 2011 | 07:49 PM
jb78L-82's Avatar
jb78L-82
My 2010 Z06 has drilled rotors-yeah I know GM put them on just for the wow factor and Porsche, Ferrari, lambo, etc!
Shark Racer's Avatar
Shark Racer
Sure there is. They can drill a couple rotors and charge extra for an upgraded brake package.
Old Jan 3, 2011 | 07:54 PM
jb78L-82's Avatar
jb78L-82
I have drilled/slotted rotors on my 2001 pontiac Grand prix and my 1994 Mustang GT both cars which have too small rotors and single piston calipers to stop 3,500 LB vehicles. Did they improve the braking?- absolutely especially from high speed and in the rain. They prevent brake pad "gas float" between the rotor and the pad and shed water better from the rotor as well.
Old Jan 3, 2011 | 07:58 PM
Mike Ward's Avatar
Mike Ward
And awaaaaaaaaaaaaaaaaay we go!
Old Jan 3, 2011 | 08:05 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Me too.
Old Jan 3, 2011 | 09:12 PM
eagle275's Avatar
eagle275
To Cross drilled rotors?????
Old Jan 3, 2011 | 09:18 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Hell yea they are good for some weight savings,
were are the hard core vetter's
Neal
Old Jan 3, 2011 | 10:34 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Same here.
Old Jan 4, 2011 | 12:19 PM
GT's 78's Avatar
GT's 78
If you gave helpful advice or just your opinion on slotted rotors it was greatly appreciated. In the future I will try to never ask another question without pouring over the archives to make sure it has never been asked before so as not to agitate anyone.
