Making a 75 a Heater Delete
Old Jan 3, 2011 | 06:27 PM
njcardave's Avatar
njcardave
Default Making a 75 a Heater Delete
I never drive my 75 in the winter. I noticed a small leak in the heater core. What size fittings do I need to block off the water pump and intake manifold? Do you think I can get them at Home Depot?
Old Jan 3, 2011 | 06:37 PM
Spuco_77's Avatar
Spuco_77
yes, 5/8 brass plugs or 3/4
Old Jan 3, 2011 | 06:45 PM
forman's Avatar
forman
you could just change the heater core I just did mine it did not leak but the previous owner tried using rtv to fix the radiator and it got in the whole system so I changed it .everyone said it was a nightmare of a job I had it done in 2 hours
Old Jan 3, 2011 | 08:47 PM
vettehardt's Avatar
vettehardt
On both of my cars, I have bypassed the heater core. I just run a hose from the pump into the intake.
Old Jan 4, 2011 | 03:20 AM
snoopykissedlucy's Avatar
snoopykissedlucy
Here's my water pump with a block-off plug from Home Depot.
I used this square style because I felt the recessed hex kind would corrode through the thin metal wall.
Old Jan 4, 2011 | 10:59 AM
BKbroiler's Avatar
BKbroiler
I used pipe plugs, from Home Depot. I think they are 1/2 inch and 5/8. Definitely no bypass hose needed.
To Making a 75 a Heater Delete
