Transistor ign question
Old Jan 9, 2011 | 03:57 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Transistor ign question
Does anyone know if this modern day GM electronic ign module can be adapted to work with a 60's GM transistor ign distributor?
http://www.gmpartsdirect.com/perform...&CATID=37.html
Old Jan 9, 2011 | 06:49 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
It will work fine...
Just hook up the two wires from the magnetic pickup in the distributor to the pair of electronic pickup wires from the GM electronic ign module.
Pull the distributor and hook it up with the module and a spark coil to test it... If you hook up the distributor's wires correctly, the spark occurs when the 8 points on the rotor align with those on the stator (pickup). If you get it backwards, there won't be a spark then, so reverse the wires.
