72 heater not working
Old Jan 9, 2011 | 04:14 PM
mansonsnc's Avatar
mansonsnc
2nd Gear
Default 72 heater not working
Any suggestions on where to start with trying to diagnose why my heater is not working, fan barely blowing and no heat.
Old Jan 9, 2011 | 04:25 PM
U17's Avatar
U17
Is the car new to you? Is there a water shut-off valve from the radiator?
Old Jan 9, 2011 | 04:32 PM
Hammerhead Fred's Avatar
Hammerhead Fred
If you can hear the fan spinning on high but feel no air flow out of any vents you likely have a blockage.
I'd check for blockage at the fan side of the heater core (or evaporator core if A/C equipped).
Over the years debris gets sucked into the fan through the wiper cowl and is then blown into the heater/AC exchanger which acts like a filter blocking all airflow into the car.
Old Jan 9, 2011 | 05:25 PM
mansonsnc's Avatar
mansonsnc
2nd Gear
No but thanks, I went and doubled checked
To 72 heater not working
