HEI dist.
Old Jan 9, 2011 | 08:26 PM
mlars's Avatar
mlars
Default HEI dist.
I have read for hours on end about recurving the hei. but I finally took the cap off mine and the weights are very loose but the cam thing the weights push on to advance the timing is pretty stiff, maybe it shuold be that way, but I dont think so. I dont have the dist. out but when I push on the weights it will force the timming forwad but it wont retract very fast or at all. I know the plastic bushings are gone for there is a lot of play there. Better get it working right before I set anything. Is there a dist. that allready has the curve set close with right vacume advance on an aftermarket unit or not? 78 l48.
Old Jan 9, 2011 | 08:34 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
I believe you have to recurve/advance any dist. you get. I just did mine a month or so ago. It makes a BIG difference! Just buy the kit, use your original weights, and replace the springs-trial and error. I used on original spring and one of the light ones supplied in the kit. Just clean the weights and all, that's what is probably causing the hang up.
Old Jan 9, 2011 | 08:35 PM
'75's Avatar
'75
I don't know of one that is already curved. Yours needs to be removed and disassembled to clean out the old grease and oil between the shaft and housing so it will advance and retard freely.
Old Jan 9, 2011 | 08:37 PM
mlars's Avatar
mlars
Do I have to pull the dizzy to do all that? I didnt look real close at how that mechanism comes out but am sure the will without pulling it?
Old Jan 9, 2011 | 08:39 PM
'75's Avatar
'75
The distributor will have to be removed to rebuild it.
Old Jan 9, 2011 | 08:41 PM
mlars's Avatar
mlars
Sorry I was late. I will pull the whole thing then, Ive pulled dizzys before but not one of these, just have to get it back in same place, any tips to make it easeir?
Old Jan 9, 2011 | 08:46 PM
mrvette's Avatar
mrvette
Whole lot of stuff to do there to make it right, I have a friend in California that redoes them, if you wish, I can get you his email...and you talk to him direct....
PM/email me for the info....it comes out correct all the way....
these later 70's chebby HEI tend to wear the studs the advance springs hang on....due to neglect more than anything else....and so it takes new springs/weights, and a dizzy machine to really dial one in good, and it comes totally apart to make it really Kosher.....
Old Jan 9, 2011 | 09:01 PM
Vette5.5's Avatar
Vette5.5
Think it's a really good idea to pull the distributor out and disassemble it, as very common the advance shaft oil gum's up causing it to stick. Sound's like what's happened to your's.
Old Jan 9, 2011 | 09:03 PM
mlars's Avatar
mlars
Yep, needs to come out.
Old Jan 9, 2011 | 09:06 PM
mlars's Avatar
mlars
I think after it is rebuilt then all I need would be a different vacume advance and spings to do the Lars curve, isnt it? Sounds like a dance, doesnt it.
Old Jan 9, 2011 | 09:11 PM
mlars's Avatar
mlars
Does anyone know what vacume advance I would nee is? Napa, part # ect...
Old Jan 9, 2011 | 09:22 PM
snoopykissedlucy's Avatar
snoopykissedlucy
Four options:
Free: dont do a thing and wonder what if........
$20: HEI recurve kit that includes weights, bushings and springs
(use the factory weights with the new bushings and the lightest springs)
$100: HEI rebuild with the weights mentioned above
$170: new HEI plus the recurve kit
FYI: The vacuum can is for part-throttle acceleration.....no real performance tuning with it...but do keep it, dont remove it.
Old Jan 9, 2011 | 09:29 PM
mlars's Avatar
mlars
So I can geta whole new hei dizzy with a recurve kit? Which one?
Old Jan 9, 2011 | 09:45 PM
snoopykissedlucy
Usually not.........all companies just throw in the stock weights and springs. You just buy the springs and weights seperately and install them yourself.
By the way, you can install weights, springs, and bushings without pulling the distributor.
I use dielectric grease between the bottom of the weights and the little plastic button. Also put some on the shaft.
Also, if you remove the rotor......you should be able to grasp the section that the rotor bolts to and twist it slightly...then let go. It should snap back into the initial position.
Old Jan 9, 2011 | 09:54 PM
mlars's Avatar
mlars
I think everything else is fine, just need to get the weights and things off, clean it up, put the bushing kit in, and lube it. Lars talked about a different vacume advance allthough. I think the original advance wouldnt get the right timing that would be added to the total timing. What kind of lube?
To HEI dist.
