ABS power brake pump location
Old Jan 10, 2011 | 03:24 PM
ZZ71S's Avatar
ZZ71S
Default ABS power brake pump location
I just got my ABS power brake eletricly boosted power brake kit.
Anyone who has this kit where did you mount the pump,
http://www.abspowerbrake.com/copperhead_320.wmv
Old Jan 10, 2011 | 10:35 PM
Ray Y's Avatar
Ray Y
You will love this upgrade! I put mine behind the drivers side gill vent for easy access (a great option for our years, my MSD box is in the passenger gill vent) and it's basically hidden.
Old Jan 11, 2011 | 08:26 AM
ZZ71S's Avatar
ZZ71S
How much trouble whas hooking up the brake pedal
Old Jan 11, 2011 | 04:51 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
What is that thing? An electric brake booster?
Old Jan 11, 2011 | 04:56 PM
Mike Ward's Avatar
Mike Ward
Appears to be. I think the name is rather decieving as it gives the impression that the car will have ABS brakes.
Old Jan 11, 2011 | 05:40 PM
ZZ71S's Avatar
ZZ71S
http://www.abspowerbrake.com/ehpm.html
Its pretty much a hydra boost that uses a eletric motor instead of the power steering pump.
I dont have power steering so no power steering pump.
Also there is just a master cylinder NO vac booster or hydra booster you can hide the pump and accumilator makes a nice clean installation .
Old Jan 11, 2011 | 10:17 PM
Ray Y's Avatar
Ray Y
The hardest part is just getting the original vacuum booster off. Otherwise very simple.
Old Jan 12, 2011 | 12:52 AM
sly vette's Avatar
sly vette
Looks kinda' pricey!
Old Jan 12, 2011 | 12:55 AM
Bowerss2's Avatar
Bowerss2
what is its benefit over hydro-boost? Unless yo are not putting out any vacuum why would you need it? the stock booster and brakes can more then lock up the tires as is.
Old Jan 12, 2011 | 09:28 AM
ZZ71S's Avatar
ZZ71S
Why do some people change to hydra boost because the stock vac system is not enough for them.
In my case I have manual brakes and steering so no hydra boost and installing that big vac booster in a manual brake car is not a easy thing.
So I found this eletric booster easier and cleaner in my case plus 1800 to 2000ish psi should stop the car pretty good.
Old Jan 12, 2011 | 10:03 AM
Mike Ward's Avatar
Mike Ward
Yup, it should-that's about the same capabilities as a stock brake system. Be aware that all four wheels will be locked up hard with far less pressure, just like the stock system.
Old Jan 13, 2011 | 12:02 AM
Ray Y's Avatar
Ray Y
Trust me they're not that touchy. I've never locked mine up un-intentionally. I have a big cam/low vacuum 555 cu in motor and the PowerBrake booster gives stable pedal pressure at any rpm or situation that I've seen. I would do this upgrade again in a heart beat. I'm in the process of installing Wilwood 13" brakes (6P front/4P rear) right now to take it to the next level.
It really cleans up the engine bay too with the booster gone. I was also able to use a valve cover that didnt have a dimple for the vacuum booster to clear. Since I don't have power steering a single belt serpentine system from MillerSpeed keeps it very simple and clean looking. It's a personal choice but I love it.
To ABS power brake pump location
