weird problem
Old Jan 12, 2011 | 07:01 PM
scyzoryk23's Avatar
scyzoryk23
Default weird problem
My vette was in garage fr last 2 weeks. When I started it today (it was 25 degrees outside today), it starts right away (even faster than my brand new Jaguar).
Anyway..I drove it to autozone (5 minutes drive)...when I come back to the car ans try to start it it doesn't want to. I have crank it for 10-15 seconds for it to start.
When I drive it for more than 20minutes (completely warmed up), its starts fine.
Any ideas.
S.
ps. Carb, dizzy, wires, plugs (and everything else related), is brand new with less than 100 miles.
Old Jan 12, 2011 | 07:56 PM
jnb5101's Avatar
jnb5101
your choke isn't adjusted properly for warm starts. ok when cold or hot, but not for in-between.
Old Jan 12, 2011 | 08:02 PM
scyzoryk23's Avatar
scyzoryk23
That was my first choice. I already change it a little, and see what happens tomorrow...
S.
Old Jan 12, 2011 | 08:04 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
yeah, carb and choke need adj. how'd you try and restart? step on the gas pedal? could have flooded it.
Old Jan 12, 2011 | 08:12 PM
scyzoryk23's Avatar
scyzoryk23
When I try to start it without pumping gas it just wont start at all (even after numerous attempts), When I pump the pedal it starts but only after few tries.
S.
Old Jan 12, 2011 | 08:29 PM
dar322's Avatar
dar322
a carb rebuild and proper setup will solve these problems. on cold starts, i step on the pedal once to set the choke and crank away. restarts usually don't require any gas, or maybe hold the pedal down halfways. if you ever flood it, hold the pedal to the metal, crank away and don't let up till it starts. Mine was set up by the Lars method. Get his papers.
Old Jan 12, 2011 | 08:41 PM
jnb5101's Avatar
jnb5101
if you have to pump the gas to get a warm start, the choke is probably set too lean. try setting the choke so that it's just barely open when the engine is hot. then open it more in small increments until it seems ok to you.
Old Jan 12, 2011 | 08:52 PM
scyzoryk23's Avatar
scyzoryk23
Carb is brand new, and setup according to Lars papers.
I was just messing with choke few weeks ago to adjust it for cold starts and I think that I might push it too far.
S.
Old Jan 12, 2011 | 09:01 PM
wombvette's Avatar
wombvette
Choke pull off not adjusted right, and maybe a little too much choke spring.
Old Jan 12, 2011 | 10:08 PM
Mike Ward's Avatar
Mike Ward
And get your Jag fixed too. Mine starts instantly even at -30
Old Jan 12, 2011 | 10:10 PM
scyzoryk23's Avatar
scyzoryk23
lol...yes Jag (my daily driver starts just fine...anytime...all the time
Lets focus on my vette
S.
Old Jan 13, 2011 | 03:53 PM
myoriginal77's Avatar
myoriginal77
it's not my jag that's the problem, the mas has issues and i won't even go there with the fer ....
Frank
To weird problem
