Head Replacement Question...
Old Jan 13, 2011 | 10:23 AM
DO2G's Avatar
DO2G
Default Head Replacement Question...
I’m getting ready to replace my heads…
I assume I need to drain the antifreeze. Can I just pull the plug on the radiator? Or, do I need to take out a plug on the block?
Old Jan 13, 2011 | 11:25 AM
Scott Marzahl's Avatar
Scott Marzahl
The plug on the radiator should work, if its corroded remove the lower hose.
Old Jan 13, 2011 | 12:46 PM
Phil Zell's Avatar
Phil Zell
Remove the plugs in the side of the block if you don't want antifreez in your oil pan
Old Jan 13, 2011 | 02:07 PM
Indiancreek's Avatar
Indiancreek
When you're finished, change your oil and filter.
Old Jan 13, 2011 | 08:26 PM
DO2G's Avatar
DO2G
perfect...thanks
Old Jan 14, 2011 | 06:21 PM
LB66383's Avatar
LB66383
Draining the radiator won't get the antifreeze level low enough in the block. But you don't have to pull a plug out of the side of the block. Once you have the exhaust manifold removed, remove one of the head mounting bolts...one of the short ones along the bottom of the head. More antifreeze will drain out, have your pan ready. Once that stops draining, use a shop vac to suck some more water out of the block.
Old Jan 14, 2011 | 07:17 PM
DO2G's Avatar
DO2G
great...thanks
To Head Replacement Question...
