1981 back-up lights (without?)
Old Jan 14, 2011 | 10:51 AM
Steven's Toys's Avatar
Steven's Toys
Default 1981 back-up lights (without?)
I recently purchased a very clean original paint, interior, matching numbers 1981. I found that there are NO back-up lights on it. The tail light lenses are all the same. Does anyone know if this might have come from the factory like this?
Old Jan 14, 2011 | 10:58 AM
blckslvr79's Avatar
blckslvr79
Previous owner removed the backup lights and installed 2 more brake lights to make it look better.
Common modification.
The backup harness is probably stuck up behind the gas tank out of the way. You could buy a couple backup lights and reinstall if you like.
Old Jan 14, 2011 | 01:48 PM
Jim Martley2's Avatar
Jim Martley2
Sad to say, the Back-up Light Delete was NOT a factory option.
I didn't like the looks of the back-up lights either and modified mine too. Here are pictures.
Here is with the new back-up light installed & extended.
Here is what I ended up fabricating to get this to work.
And here it is installed .
Old Jan 14, 2011 | 02:03 PM
blckslvr79's Avatar
blckslvr79
Jim-
How much to make me one?
Old Jan 14, 2011 | 02:10 PM
Jim Martley2
Originally Posted by blckslvr79
Jim-
I made this up about 4 years ago and at that time the Linear Actuator was around $200. There is some re-wiring that has to be done and a Relay installed in the wiring to make it work automaticaly when you put it in & out of Reverse. It wasn't an "easy bolt-on instillation", by any stretch of the imagination. Here is a link to the thread discussing the Relay I ended up buying. http://forums.corvetteforum.com/audi...cs-wizard.html
Jim
Old Jan 14, 2011 | 02:57 PM
SteveG75's Avatar
SteveG75
My setup. Note the small lights under the bumper that fill the requirement for backup lights.
Old Jan 14, 2011 | 03:12 PM
JimT's Avatar
JimT
SteveG75,
Where did you find those small, thin lights? I have a 72 with bullet tail lights and need backups. Those are quite un-noticeable. I had been using l.e.d.s in bolts - "lite-in-bolts" (for the license tag bracket) but they were not bright enough.
Old Jan 14, 2011 | 03:16 PM
Rebelrob's Avatar
Rebelrob
Jim, I like the stock lens look, if what I am seeing is correct. Been wanting to make this mod myself and using the bubble lights as option 2. I will shoot ya a pm.
Old Jan 14, 2011 | 09:45 PM
SteveG75's Avatar
SteveG75
Originally Posted by JimT
SteveG75,
Jim,
They are just LED accent lights from Autozone. Not super bright though. They do have some thin fog lights that would probably do the trick though.
Old Jan 15, 2011 | 04:56 PM
GS977's Avatar
GS977
it does look much better with 4 brake lights!!! might have to add this mod to my to do list
Old Jan 15, 2011 | 05:40 PM
...Roger...'s Avatar
...Roger...
That's pretty cool !
Old Jan 16, 2011 | 09:15 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Mini Cooper reverse light
Old Jan 16, 2011 | 09:16 AM
SmokedTires
St. Jude Donor '05
Nice job Jim
Old Jan 16, 2011 | 08:43 PM
bluegtp's Avatar
bluegtp
To 1981 back-up lights (without?)
