if you use radio suppression or spiral core sp wires you should not need shielding
dunno what kinda ign you have now ... you don't Specify ... but ...
if you have a GM type HEI electronic distributor (with coil in cap) ... get a box & lid for '75 thru '77 ... you can probably bend your old brackets or get em for 75-77
It is possible to modify the stock shielding to fit over the HEI dist. but you can't hide the cap. You will need to cut the shielding, so to do it is expensive and not reversible. You will be able to see the cap from the front and back.
