Reverse Lights
Old Jan 17, 2011 | 05:39 PM
desertdogs50's Avatar
desertdogs50
Cruising
Default Reverse Lights
My reverse lights are not working, bulbs have been replaced, fuse checked, other than replacing the actual switch what could be wrong, all ideas welcome. Thanks
Old Jan 17, 2011 | 05:57 PM
LB66383's Avatar
LB66383
It could be the switch, it could be a bad ground, it could be a poor connection somewhere. Are you getting voltage to the bulbs when it's in reverse?
Old Jan 17, 2011 | 06:30 PM
desertdogs50
Cruising
Default Reverse lights
I'll Check and try to run it down with the volt meter
Old Jan 17, 2011 | 06:31 PM
myk7's Avatar
myk7
Automatic or 4 speed? Tried running through all gears?
Old Jan 19, 2011 | 09:41 PM
Go Vette's Avatar
Go Vette
My car failed inspection last year. I didn't even know the lights weren't working. I took it home and looked underneath the car. The little rod that connects the switch at the tranny had come loose. A 10 cent retainer from the hardware store fixed it. I'm sure the geniuses at the shop would've have charged at least a hundred clams to fix it. Hope yours is as easy.
To Reverse Lights
