Hood room
Old Jan 17, 2011 | 09:03 PM
Shift_Happens's Avatar
Shift_Happens
Default Hood room
I would like to upgrade my stock carb/intake setup without changing the stock hood on my 73. I'm thinking a Holley carb with an Edelbrock airgap manifold. Has anybody tried this setup?
Old Jan 17, 2011 | 10:43 PM
Ray Y's Avatar
Ray Y
It would help to know which hood you have and what air cleaner/base you want to run; and if you are using a standard block height deck.
I have an Edelbrock RPM AirGap intake (75624) with a Holly 4150 bodied carb with a 2" K&N Extreme air cleaner on a drop base, on a std deck height block; and I have ~1/2" of clearance to the top of the L-88 hood on my '70.
Old Jan 18, 2011 | 08:32 PM
Shift_Happens
Standard hood with a stock block. I really don't want to change the hood since it has recent paint. As for the air cleaner, I'm open to anything that will fit under the hood.
Old Jan 19, 2011 | 06:24 PM
Shift_Happens
Anybody?
Old Jan 20, 2011 | 08:35 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Originally Posted by 1973ragtop
Anybody?
With that carb and intake and a stock, small block hood you are sure to have clearance issues.
Old Jan 20, 2011 | 10:48 AM
Patrick73's Avatar
Patrick73
The Edelbrock Performer Air Gap (2601) will not fit under your stock 1973 hood.
The Edelbrock Perfomer ( 2101 or 3701) will fit. Weiand also has a low rise aluminum dual plane manifold that will work for you. These manifolds will accept your Q Jet or a Holley spread bore 4165/4175 without causing any 1973 hood clearance problems.
Old Jan 21, 2011 | 02:58 PM
garrysaw's Avatar
garrysaw
Same topic, different car. I have a 74 with stock hood and want to replace the intake with an Edelbrock Performer Intake 27014 and Edelbrock 1406 Carb. I've measured the height from the top of the carb to the theromostat housing on both the original and the replacements, and there is approximately 3/8" difference, the Edelbrock stuff is higher.
Old Jan 21, 2011 | 03:32 PM
bluedawg's Avatar
bluedawg
If you search this & other vette forums it can be done with ether a drop base filter or specter dual inlet low rise cold air intake. All this being done with the rpm air gap. But with either configuration you could possible be choking the air flow alittle.
Old Jan 21, 2011 | 07:31 PM
U17's Avatar
U17
I can't help .....
Old Jan 21, 2011 | 08:37 PM
Ray Y's Avatar
Ray Y
It will not work with the small block hood even with a drop base on the air cleaner. L-88 hood yes. Intake, carb, & air cleaner in my earlier post.
Old Jan 25, 2011 | 09:07 PM
Shift_Happens
Good info
Thanks Patrick
Old Jan 26, 2011 | 01:15 AM
DRIVESHAFT's Avatar
DRIVESHAFT
A buddy of mine has a 71 with the stock small block hood.
He runs a Chinese knock off of the RPM Air Gap & a Holley Street HP 750.
The air cleaner base is a deep drop & the filter is only a 14 x 2", but it fits.
To Hood room
