Expected life span of a composite leaf spring
Old Jan 19, 2011 | 09:58 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Default Expected life span of a composite leaf spring
My '71 had a composite rear leaf spring when I got it, and as per the PO, it has it since long time (not sure how long, but I can guess between 10 to 15 years), is it wise to replace at this time just as a precautionary measure? , or am I worrying too much about it? , this is a daily driver and its not cool at all to break it off at 60 MPH!
One more thing related to the same topic, since its a daily driver, I thought about upgrading the suspension to a front/rear composite leaves, but I hear too many stories about them cracking at some point of their life, is it something native to the composite springs to crack, or is it simply an installation/installer fault?, it may sound ridiculous, if my car is just floating on a single composite piece on all four corners, IMHO it makes me feel a little shaky.
Old Jan 19, 2011 | 10:02 AM
alswagg's Avatar
alswagg
I replaced mine in 2009, it was original so 28 years???? I am sure it probably needed to be replace at 27 though lol Al
Old Jan 19, 2011 | 10:50 AM
mrvette's Avatar
mrvette
I ditched the stock spring when I got the car, back in '95, and so the VBP single/center mount spring been on there since, just fine....
the exhaust does hand a tad LO about 2" below the spring....that is the only trick there....
oh, Bilstein shocks are much better than KYB's I had....
Old Jan 19, 2011 | 03:19 PM
Surfer69's Avatar
Surfer69
My daily driver has had it on for 8 years now. I made sure to protect from exhaust by rapping heat resistant stuff around spring, otherwise I would think it could fail much earlier.
Old Jan 19, 2011 | 04:59 PM
jb78L-82's Avatar
jb78L-82
I have had my 360 composite (VBP spring) on my 78 since 1987 (about 24 years) and it is perfectly fine and I have no intention of replacing it any time soon since I check it a couple of times per year and it seems fine. There is no exhaust wrapping on the pipes to protect the spring from the heat but is about 2 inches below the spring in that area. Hope that helps!
Old Jan 20, 2011 | 10:27 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Ideally they should last as long as the car barring any accidents or damage. They will eventually need the rubber bushings replaced, after 25-30 years probably.
Old Jan 20, 2011 | 09:07 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I believe the lifespan would be anywhere from the time you bought it until it cracked
Old Jan 20, 2011 | 09:30 PM
milo30's Avatar
milo30
The only thing that I heard negative about the lifespan was if it got damaged from the heat from the exhaust the material could get weak. I'd say you don't have that issue if it's been on that long. I believe in "if it aint broke, don't fix it" but if it gives you peace of mind, they aren't that expensive to replace.
To Expected life span of a composite leaf spring
