Hurst Shifter Kit Installation
Old Jan 20, 2011 | 12:31 PM
samuk's Avatar
samuk
Default Hurst Shifter Kit Installation
Do I need to remove the transmission to install this kit, instructions says no, but anyone with experience in it?.
Regards,
Old Jan 20, 2011 | 01:14 PM
joefloyd's Avatar
joefloyd
No you do not need to remove the trany, I installed a hurst shifter in my 80. You will need to get the car up enough to work under it. The Hurst shifter is much better than the stock shifter, you will love it.
Old Jan 20, 2011 | 01:36 PM
reddog76's Avatar
reddog76
You guys have details on what shifter to use? 76 4 spd.
Old Jan 20, 2011 | 01:47 PM
samuk's Avatar
samuk
My plan was to install the linkage kit with original shifter/lever, would it be possible?.
Old Jan 20, 2011 | 02:09 PM
billsfan's Avatar
billsfan
I don't think so. Zip sells a vette style shifter for the Hurst linkage, part # ST-372.
Old Jan 20, 2011 | 02:21 PM
samuk's Avatar
samuk
theeeere goes more money..... geeeeeee
Old Jan 21, 2011 | 10:06 AM
billsfan's Avatar
billsfan
If you've owned your vette for more than a week, you realize that an extra $80 is just a drop in the bucket (or the ocean). We should run a poll on fixer-uppers. I'll bet that most guys end up spending more to fix up their car than they spent to buy the "bargain".!!
Old Jan 21, 2011 | 11:25 AM
harrin's Avatar
harrin
No it will not work, you will need the Hurst linkage, as it is different from the stock linkage.
Old Jan 21, 2011 | 02:18 PM
3rd_Vette's Avatar
3rd_Vette
My Hurst shifter is Awesome!
Old Jan 21, 2011 | 03:44 PM
69/03vette's Avatar
69/03vette
Regards,
If your adding this into the car in your avatar (69?) you might find as I did needing to cut about a 1/2 inch off the 1st - 2nd linkage rod. It would'nt go ito 1st gear because of hitting something (can't remember exactly what the rod was hitting) just a heads up incase you have the same isssue. you'll love it.
Old Jan 22, 2011 | 11:10 PM
samuk's Avatar
samuk
The idea was to get a kit to "stiff" the shifter a bit, but I got the wrong part, so will sell it and get a rebuild kit instead.
Old Jan 23, 2011 | 10:42 AM
onebadmofo's Avatar
onebadmofo
I bought this from CC it is great with the stock looking shifter handle, it shortened the throw prolly 30 to 40 % and much more positve feel.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Old Jan 23, 2011 | 06:48 PM
mlub's Avatar
mlub
Regards,
I replaced my old hurst setup with a new one a couple years ago, and no you dont have to remove the trans. I do recall that it was a tight area to work in, but if I can do it so can you
Old Jan 28, 2011 | 01:44 PM
reddog76's Avatar
reddog76
CAn you adjust the shifter on a 76 BW to remove too much excess "play"? It shifts fine, just seems the "throw" goes a little too far in the console.
Reddog76so
Old Jan 28, 2011 | 02:04 PM
Roco71's Avatar
Roco71
One of the vendors was selling a "Stock" looking shift lever and **** that would fit a Hurst tower and linkage. I am not sure if its available or not
I found it http://www.ecklers.com/corvette-shif...1968-1976.html
To Hurst Shifter Kit Installation
