Aluminum Head Question?
Old Jan 24, 2011 | 10:05 PM
DO2G's Avatar
DO2G
Just curious...did you call Brodix to get their thoughts?
Old Jan 25, 2011 | 04:27 PM
trainor's Avatar
trainor
Yes, and they too think it could be a manifold problem. Thanks again for the help.
Old Jan 25, 2011 | 08:22 PM
trainor's Avatar
trainor
Originally Posted by TopGunn
I have those heads, they're a great set of heads.
When you said it smokes when you put your foot in it, my opinion it's not valve seals. Are you sure you don't have an intake gasket that's torn or got messed up somehow during assembly?
After reading your reply the other day I decided to take it for a ride. When I shut it of and restarted 5 minutes later it smoked and quite a bit. Then my mechanic noticed that after it was running for a few minutes it was still smoking a very small amount. I then drove it for 15 minutes and got out and if you looked close you could barely see smoke still. I'm not noticing any at acceleration. These rings are not an issue, this started immediatly after fire up with the new heads. My mechanic agrees that it could be a intake problem but he seems to think it would stop smoking after being run for a few minutes. Well I'm hoping you can give me your input, sure will be appreciated.http://images.ibsrv.net/ibsrv/res/sr...illy_nilly.gif
Old Jan 25, 2011 | 09:06 PM
TopGunn's Avatar
TopGunn
Well that symptom is a classic valve seal symptom but with brand new heads it sure seems unlikely they're bad. Does it smoke from both sides or just one? If from one side possibly you could narrow it down some by looking at the plugs after a brief start up. I would be nice to have an idea where the oil was coming from but I think you're going to have to pull the intake a have a look. If it's smoking equally from both sides I'm kind of stumped how it could be head related. Maybe some others can offer some suggestions.
I suppose it's possible you have a defective head that's sucking oil somewhere too.
Old Jan 25, 2011 | 09:46 PM
Scott Marzahl's Avatar
Scott Marzahl
I think its an intake to head sealing problem. I've chased this same type of thing in the past with milled heads where the standard thickness gasket would not seal. In your case the heads may be a bit taller throwing off the geometry just enough not to make a good seal.
Old Jan 26, 2011 | 01:06 AM
DRIVESHAFT's Avatar
DRIVESHAFT
FYI - In case you didnt know, Brodix does not install valve seals on the exhaust guide unless you request them.
Old Jan 26, 2011 | 07:20 AM
TopGunn's Avatar
TopGunn
No kidding..........I never knew that. Wonder why??
Old Jan 26, 2011 | 10:27 AM
trainor's Avatar
trainor
Yes the smoke is coming from both sides but I have a crossover in my exhauste system.
Old Jan 26, 2011 | 10:30 AM
trainor's Avatar
trainor
Will not having valve seals on the exhauste guide possibly be causing this problem and why would they not install them?
Old Jan 26, 2011 | 12:16 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Brodix says that they were asked not to install them so many times that they just stopped using them.
You have to remember that not all that long ago the racing market was the only people buying from companies like Brodix.
On a race car, many guys feel like well lubricated valve guides are more important than having an engine that never smokes.
Not having the exhaust seals will very likely cause the puff of smoke at start up.
Opinions seem to vary about after the engine has been running for a while.
Its easy to argue that the exhaust side is under pressure once running and not a worry, but I have heard of (but not seen) people adding the seals and stopping the constant smoking.
Its worth a shot anyway.
Old Jan 26, 2011 | 06:33 PM
trainor's Avatar
trainor
I contacted Brodix today and found out that they do not install the valve seals on the exhaust side. This kinda irritates me cause when I spoke with the dealer he asked me whether it was for street or strip. I told him street. At this point you would think this way, who wants to take a beautifully restored corvette to a car show and start it up and have it smoke. It looks like I work for the mosquito abatement program. Don't get me wrong I think so far the quality of the heads is great, but I think they need to think street driving if there gonna sell to street and show people. So anyway do you guys think that installing these will take care of the problem. The way I see it you would think that on the exhaust stroke that it would be pushing out instead of being able to suck oil in. Well Brodix was kind enough to send me the seals($28) YIPPEE and I get to eat it for the labor. Word for rest of you, request exhaust seals in when you order what is advertised as a complete set of heads. Thanks for all the help guys.
Old Jan 26, 2011 | 07:57 PM
TopGunn's Avatar
TopGunn
I don't think your car is smoking because there's no valve seals on the exhaust valves, there's some other problem. My car doesn't smoke a bit and never has. Did Brodix say it was very likely smoking because the seals were not present or did he give them to you because you asked?
I get the impression from your description that the car smokes big time when you start it. I don't see that happening on a new set of heads even without seals.
Let us know how this works out
Old Jan 26, 2011 | 08:02 PM
  #33
trainor's Avatar
trainor
Yeah I asked for them. I think I'm gonna change the intake gasket and check that out. Fel-Pro gasket 1256 is what edelbrock suggests for a good seal, it has a silicone bead that helps difficult situations. What do ya think?
Old Jan 26, 2011 | 08:12 PM
  #34
trainor's Avatar
trainor
When you put your heads on did you notice any smoke at all. If not then I think I have a intake leak. Also what were your heads on a SBC? Also what intake do you have and what gasket did you use. If you have this info I'll appreciate it. Thanks
Old Jan 26, 2011 | 08:27 PM
  #35
TopGunn's Avatar
TopGunn
That's a good gasket. I hope you see something when you pull it. Good luck
Old Jan 26, 2011 | 08:40 PM
  #36
TopGunn's Avatar
TopGunn
I didn't notice any smoke, there was probably a little buring off the piston tops and combustion chamber but I never saw it.
My heads are on a 350, cam is the same one they use in the ZZ383, my intake is a Weiand and I used the Felpro 1204 gasket. Head gasket was .032 thick.
I know this sounds real stupid but you don't have a Vortec intake and regular heads do you?
Old Jan 26, 2011 | 08:45 PM
  #37
trainor's Avatar
trainor
No not a vortec intake. Well were gonna install the valve seals in the exhaust side and the new intake gasket and cross our fingers. Thanks alot for all the help guys!!!http://images.ibsrv.net/ibsrv/res/sr...illy_nilly.gif
To Aluminum Head Question?
Old Jan 26, 2011 | 09:48 PM
  #38
Scott Marzahl
The 1256 is not the thick seal like the 1245 Larry recommended but hopefully you can see the impressions in the old gasket and see if they were deeper at the top than at the bottom which means you need the thicker gasket.
Old Jan 28, 2011 | 08:34 AM
  #39
jackson's Avatar
jackson
Lotsa regional CT racers run zero-deck 350 with HEAVILY milled 76cc iron heads (cut to 70cc).
Their intakes never fit right out of the box. So, intake boltholes get "elongated-oblonged" with a die grinder or drillbit; Aside from that, rules require alum EB2101 with absolutely NO further mods/machinework. But, even so, they'll usually leak. And seasoned builders know that up front ... so ... builders assemble to Prevent likely leaks.
Leaks Prevented with PLAIN CHEAP intake gaskets and judicious use of hi-temp RTV silicone around all charge ports & water ports. YMMV.
Old Feb 19, 2011 | 06:36 PM
  #40
trainor's Avatar
trainor
Well after installing new brodix heads I had a large amount of blue smoke after a start up. Only did it after motor was off for 10 minutes or so. Someone suggested valve seals others suggested intake leak. Well Brodix only installs seals on the intake side, seems that for the strip, guys prefer some more lubrication in the exhaust side. So Brodix doesn't put seals in the exhaust side unless you ask them to. We installed the seals today and I'm happy to say that the smoke is a thing of the past and warm start ups are easier. Brodix heads are great, but remember if you have a nice show car you probably want to make sure to order with seals on both sides. Other than that their Tech Guys were very helpfull and I would suggest these heads to all you guys, Thanks for all the help.
