72 wiper door
Old Jan 25, 2011 | 07:49 PM
rjm5's Avatar
rjm5
Default 72 wiper door
Help, I have a 72, when I activate the wiper switch the wiper door only raises up 1/2 way. I can pull the door the rest of the way up and the wipers work properly. when turned off it closes. I have checked most everything including lubing the arm joints. the actuator does not seem to get enough pressure. any ideas what the problem is?
Old Jan 25, 2011 | 09:15 PM
...Roger...'s Avatar
...Roger...
Sounds like the witches hat seal is leaking.
Old Jan 26, 2011 | 08:37 PM
rjm5's Avatar
rjm5
Ok, I looked at the rubber plug in the back of the actuator and it is very dry and loose in the can. Thanks for the input!
To 72 wiper door
