Need AC Comp Bracket pics
Old Jan 25, 2011 | 07:50 PM
reelthing's Avatar
reelthing
Default Need AC Comp Bracket pics
Well, It been a month since i took of the ac compressor brackets and air pump on my 82 vette. The good news is my new headers sidepipes are installed; but now I have a couple of ac brackets and bolts and no clue how they go back. I know I need a spacer to put the ac bracket on the manifold stud, but the rest is confusing. I have a GM manual, but the one pic I found is pitiful. Can someone send some pics for a 1982 application or appropriate aim diagrams so I can reinstall my ac compressor? Also, any tips on how to reinstall the oil dipstick tube as that bugger wont go back in very easily....Pat
Old Jan 25, 2011 | 08:26 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Had this pic handy, don't know if it'll help any.....
Old Jan 25, 2011 | 08:52 PM
scottyp99's Avatar
scottyp99
Is your manual the assembly manual? It should show pretty detailed drawings.
Scott
Old Jan 25, 2011 | 10:18 PM
GS977's Avatar
GS977
i can take some pics for you tomorrow.
Old Jan 25, 2011 | 11:37 PM
snoopykissedlucy's Avatar
snoopykissedlucy
I got a ton of pics of when I took my 1981 Vette apart. Let me know if you need more.
Old Jan 26, 2011 | 09:33 PM
reelthing's Avatar
reelthing
Default Got it
Thanks for pics. I was able to reassemble tonight. One question though.. Since I am now using headers and not the stock exhaust manifold, can I choose not to install the one last bracket arm that used to go from the top of the ac compressor belt adjustment bracket to the number 3 exhaust manifold stud.? The header bolt will not be long enough to hold the bracket arm and still bolt into header. I cant use the stock stud/bolt since the primary from the header interferes with the long stud/bolt. It seems to me the ac compressor is really solid without that last arm/bracket anyway...Pat
Old Jan 26, 2011 | 10:20 PM
snoopykissedlucy
I'm confused, mine only has one stud on the first header hole. Is that what you're talking about? Yes, you do need this to support the side loading. Go to home depot and get a stud and 4 nuts. You can use one nut to snug the header and the others to use as jamb nuts and tighten the bracket.
Old Jan 26, 2011 | 10:52 PM
KapsSA's Avatar
KapsSA
That top support bracket goes to the third or fourth bolt on the INTAKE manifold.
Just below the carb. There should be a bolt/stud thingy.
Old Jan 26, 2011 | 10:55 PM
KapsSA's Avatar
KapsSA
Old Jan 27, 2011 | 04:51 PM
reelthing's Avatar
reelthing
Default I have 82 with TBI
No carb, just TBI. According to GM manual, the support bracket goes from third exhaust manifold bolt to top of AC bracket...help
Old Jan 27, 2011 | 08:06 PM
KapsSA's Avatar
KapsSA
Oops, didn't think of that:o
To Need AC Comp Bracket pics
