How do I install a door switch?
Old Apr 10, 2002 | 07:33 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default How do I install a door switch?
I tried and the thing keeps sliding back and forth. I'm afraid to keep tightening it and strip the frame metal. What is the technique?
Old Apr 10, 2002 | 08:23 PM
Pete79L82's Avatar
Pete79L82
Default Re: How do I install a door switch? (Budman78)
If it is sliding by itself then it is time to replace it. Screwing it in tigher will not stop it. Get a new switch, unscrew the old one, put the wires on the new one, and screw it back in. When you close the door it will adjust itself.
Old Apr 10, 2002 | 09:30 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Default Re: How do I install a door switch? (Pete79L82)
It's a brand new GM switch.
Old Apr 10, 2002 | 10:07 PM
Pete79L82's Avatar
Pete79L82
If it is a new switch and it is moving too easy then it is defective. You should not be able to easily move the switch in and out.
Old Apr 10, 2002 | 11:56 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
You don't think they replaced it with a compression type adjustable switch?
To How do I install a door switch?
