Wobble at 52 mph?
Old Jan 31, 2011 | 11:49 AM
Chromie69's Avatar
Chromie69
Originally Posted by PRNDL
what do you mean by, do a 180 on the tire? If it is raised letters out do you mean change the tire to raised letters in?
I was thinking if you don't have a friend to swap tires with you could try rotating your tires, maybe front to back, to see if that makes a difference.
it means breaking the bead on the tire and rotating the tire on the rim 180..really a simple thing to do at any tire shop.
Old Jan 31, 2011 | 11:51 AM
TNX ZORA's Avatar
TNX ZORA
I think he means rotate tire 180 deg. relative to rim.
Old Jan 31, 2011 | 11:55 AM
Chromie69's Avatar
Chromie69
if you really want to do it right find a shop with a Hunter brand tire balancer with a road force option..it tells the installer where the high and low spots are on the wheel and tire and how to match the tire and wheel so that it will cancel out the difference between the two.
Old Jan 31, 2011 | 01:36 PM
Wrencher's Avatar
Wrencher
All good ideas. Remember, it just needs to be the same bolt pattern on a 15" rim for the loaner set of tires, the actual design and brand doesn't matter, so we're talking Camaro/Firebird. Olds Cutlass, Buick Regal, etc...
I would imediately look at the driveshafts if that doesn't fix it, especially since you feel it throughout the car at a specific speed, and rotating the tires front to back didn't change it, right? My Mustang had an out-of-balance driveshaft and it did exactly what you describe at 70 mph. OK at 60 and 80.
Hans
Old Aug 26, 2011 | 09:25 AM
Surfer69's Avatar
Surfer69
Update for the record:
Turned out to be bad idler arm. Replaced idler arm and pscv and wobble is all gone. Should have realized earlier but at least mystery is solved. Pretty sure pscv had nothing to do with it but needed to replace anyway.
Old Aug 26, 2011 | 12:56 PM
dntoearthman's Avatar
dntoearthman
Bingo ! thats the machine, one thing that also helped my intermitant wobble was a front spreader bar !!!
Look for a Hunter tire balancer that does road force..
Old Dec 31, 2011 | 07:36 AM
kirt8548's Avatar
kirt8548
I'm having a similar problem. I have searched and found that a local tire store has a machine that will actually shave the tires on the rim and I believe on the car. I'm going to give that a try.
Old Dec 31, 2011 | 12:34 PM
hugie82's Avatar
hugie82
180 the tire on the rim only works when a tire balances out with a lot of weight
Old Dec 31, 2011 | 12:37 PM
hugie82's Avatar
hugie82
Pinion bushing will cause your problem too
